12-27-2022, 12:39 PM | #1 |
Rep 4
I Had these codes pop up in my F82 after lightly accelerating. The car is also running slower than usual. Also started to run a little rough if idling for a couple minutes. Has anyone run into an issue like this? I’m also looking to upgrade to the EU5 injectors does anyone recommend a retailer or have the correct part numbers?
TIA Update: I found that the charge pipe o-rings were leaking, so I replaced them and I haven’t had the codes pop up yet and runs a lot smoother now. Now I have the problem of when the car gets to around 6200 rpm in just 3rd gear it feels like it hits a rev limiter, but if I let off and continue or shift it drives normally. |
12-28-2022, 06:58 AM | #3 |
17
Rep 10
Drives: 2018 m3
Maybe a cracked charge pipe? Do you have any mods?
Eu5 injectors - 13647599876 BMW Decoupling Element: 13537577649 |
BMW M4F1A0.00 WarMachineM356.50 |
