11-19-2022, 12:38 AM | #1 |
Rep 2
BMW M4 Battery Issues
Hello everyone,
I’m new to the forum. I’m having battery issues with my F82 and i’m not sure what to do or what the problem is. The error code is “ Electrical Power Supply Limited”. A new battery is a couple thousand easily so looking for alternatives. Do I need a new battery? Maybe a bad cable? Any help would be appreciated. Thanks in advance! |
11-19-2022, 04:56 AM | #2 |
475
Rep 628
How long has this been happening? Did you just get this car?
First thing I would do is check tightness of the power supply connections both at the battery and under the hood. The check what error codes you currently have. Then check the battery voltage both with the car running and off. Charge the battery and see if the battery can hold voltage overnight. |
11-19-2022, 12:17 PM | #3 |
189
Rep 682
Drives: 09 328i Sport 6MT
I'm sorry...why is another battery a couple thousand dollars?
11-19-2022, 12:32 PM | #4 |
77
Rep 88
They use a Lithium-Ion battery.
2017 Yas Marina Blue M3 ZCP
11-19-2022, 12:44 PM | #5 | |
3290
Rep 6,732
OP Are you original owner? Did someone replace the battery at some point? Is it the original battery? Heading down the path that the battery may need registration or is coded incorrectly. Also the negative IBS cable could be at fault or the small connector isn’t connected (black/red wire) |
11-19-2022, 02:18 PM | #6 |
Racecar Driver
1309
Rep 1,982
Drives: BMW M4
It's a lithium-ion battery, not an AGM or lead acid. The part number is 61-21-8-047-221
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
11-19-2022, 06:10 PM | #7 | |
Rep 2
11-19-2022, 09:22 PM | #9 | ||
381
Rep 1,174
Drives: BMW
BMWCCA member 429244
11-19-2022, 10:14 PM | #10 |
Rep 13
Check voltage of the battery with some battery tester, used lion is up to 1k, I have agm just needed to change negative cable from reg F30, can program it with bimmerlink so the car doesnt overcharge I guess but didnt find it crucial as long as you swap it with same amperage etc
11-20-2022, 01:29 AM | #11 |
2897
Rep 3,729
Anti gravity batteries should be on sale for Black Friday. I'm planning to pick one up as a spare since our lithium batteries start to go out after 6+ years.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
11-21-2022, 11:57 PM | #12 |
72
Rep 98
I know Iam wrong here but I cant help think a 2 thousand dollar battery should at least last close to a decade, I've had standard car batteries last that long. Op you ever get the issue sorted out ??
paul dangelo
11-22-2022, 06:25 AM | #14 | |
///M SubDriver
1843
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
That said, lithium battery technology (of which there are different "flavors") is continuously improving, including becoming more cost effective…..
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
11-22-2022, 11:08 AM | #15 | |
Racecar Driver
1309
Rep 1,982
Drives: BMW M4
I've never had a standard lead acid or AGM exceed 4 years in my old cars and I daily drove them haha. Battery warranties aren't even long anymore. They used to be like 6 years or something. Now they're like 3 years? 4 years from Costco.
N1rve
