11-06-2022, 10:05 AM | #1 |
45
Rep 102
EPS Coding with esys
Kind of looking for a step by step on how to code the eps on my m4. I just recently installed a used steering rack and a new driver headlight control module. From what Ive researched so far it's The following:
[Removed] Repeat for FLE? EDIT: For anyone that stumbles upon this in the future: this video works perfectly. This worked with the engine running for the EPS and FLE. Connect to car (F20) *not direct* Connect via VIN Read parameters from VCM Read VO Save VO Activate FA Read (VCM) Save vcm data as SVT Set svt menu to complete flash Check vcm tab in expert mode for istep version Istep read is located at the bottom Calculate SVT target Save SVT target as SVT_soll Calculate TAL Save as SVT_tal Change to expert mode Go to TAL processing In TAL load the TAL file from earlier In SVT, load the SVT_soll file from earlier Read FA Select ONLY the ecu's that you need coded Note: this shows all the ecus that can be coded Go to parameters tab Select overwrite existing installed ECU list Open esys settings Go to options tab Unselect the following: "Update MSM after TAL execution " "Update VCM after TAL execution" Go back to the ECU tab in TAL editor Check software compatibility Begin flash with 'start' button. You car will make some noises and throw some errors. Once it's done you can clear errors from transport mode following these steps: Go to external applications tab (located on left) Double click transmitter Scroll to the bottom to the long line if text Select the text Hit connect Click send Wait until the send button us no longer greyed out Turn off ignition by pressing the star button 2 times Wait a little Start the car and you should be all good or to go! Could this be done without a power supply or just a battery charger? Last edited by F80manz; 07-26-2023 at 04:47 PM.. |
11-06-2022, 10:55 AM | #2 | |
BimmerPost Supporting Vendor
1793
Rep 3,062
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
11-06-2022, 12:30 PM | #4 |
1793
Rep 3,062
Of course
