09-14-2022, 10:22 PM | #1 |
Rep 11
Buying a 6 series. Please help!
Hey everybody. This is my first post.. i’ve always been a benz guy since 16 had a c230 coupe, then clk500, c300 , E350, ML350..now it’s time for a change. I was thinking a newer model 3 series like 2019-2020 but I like the 6 better and can’t believe it’s 10 years old car.. i am looking at a 2014-2015 under 60k miles and i was just wondering 650i or 640i ? I was hearing a lot about 650i has issues with engine and oil leaks ? It’s hard to find a 640 coupe.. they are mostly all gran coupe,, i like both body style but the coupe just looks like it goes harder.. but any advice would help … and any good after market warranty’s out there or are they all scammers ?
THANK YOU Last edited by beg4m3rcy703; 09-14-2022 at 10:37 PM.. |
09-15-2022, 07:26 AM | #2 |
1205
Rep 2,918
The problems with 650 engines after 2012 are overstated. Most people here have no issues. I have had zero issues and it does not leak or use oil. I never buy warranties so I can't help you there, but if you search you'll find lots of threads on that topic.
09-15-2022, 09:07 AM | #3 |
17
Rep 104
The lingering (i.e. post-2012, earlier engines were a disaster) known engine issues are generally minor:
-high pressure fuel pumps can fail, BMW extended warranty to 100k miles -fuel injectors can clog/fail, BMW extended warranty to 100k miles -spark plugs and ignition coils can degrade and cause rough idle and intermittent missing, solution is to replace the factory parts -annoyingly high oil consumption, typical to have to put in a couple quarts between oil changes -hoses near the turbos in the hot vee tend to get heat cycled and can crack, solution is replace pre-emptively before they get too old for peace of mind That's about it off the top of my head, it's not nothing but it's not enough to scare me off, I did plugs/coils shortly after I got the car at ~35k miles, I've had two HPFPs fail on me, both replaced under warranty with a loaner in the meantime, keep a 5qt jug of oil in the garage to top it off when the computer tells me to, thinking about replacing hoses since I'm approaching 65k now...and enjoying the V8 experience. Opinion here, but the 5/6 platform is too damn heavy for the buzzy/revvy 6cyl to feel right. Sure it makes enough power but a big heavy cruiser feels right with more low-rev torque and effortless thrust. |
09-16-2022, 02:23 PM | #4 |
11
Rep 101
I have a 2014 650 with no issues. I also agree with TGrits10 regarding the 6cyl. Its a big heavy car and im not sure it would feel the same with a 6. Although ive never driving one...
09-16-2022, 05:43 PM | #5 |
Tinker
39
Rep 161
As to the 640i, am thrilled with it. Am coming from a 535-ish HP aircraft carrier (aka QP GTS). While I don’t get the same 0 to 60 time, that’s something I would assess for fun and not during regular driving. It shifts smooth as butter and has all the power I could want for regular (yes I may have a lead foot) driving. No idea what the reference to buzzy/revvy is. It IS still a heavy car. Not as nimble as my 300zx but still plenty fun to challenge myself on the last sharp bottom-of-the-hill R turn on my way home.
Drive them both and figure out what works for you. If you maintain it properly (oil change 5-7K, etc), turn wrenches or don’t mind a visit to the shop once in awhile, you’ll be fine either way. PS: after being on the forum for awhile I am with Opie55 on no warranty. There is so much information available that even if I had to get a diagnostic, am confident I could manage what might come along in the next many Ks of miles. |
09-16-2022, 05:51 PM | #6 |
Tinker
39
Rep 161
09-16-2022, 11:26 PM | #7 |
Rep 11
Thanks guys… is it worth it to get a 2015 because i heard of a face lift? But all i see is a new design steering wheel ? Lol..can someone tell me exactly what changed ?
09-16-2022, 11:27 PM | #8 | |
Rep 11
I heard PWI was decent too? I probably won’t end up getting any extended warranty if its scam with lot of fine print |
09-17-2022, 01:28 AM | #10 |
1205
Rep 2,918
I forget what all changed. I really like the new steering wheel if you get an MSport car. The iDrive controller is larger, and is a touch pad. There's probably a list out there. But it's not a lot.
09-17-2022, 01:37 AM | #11 |
Tinker
39
Rep 161
Your upgrade-ability to CarPlay, etc. is much simpler after August 2016 build date.
Edit: MY 2017, Aug 2016 build date (previously said August 2017) Last edited by FlyinLowSD; 09-24-2023 at 05:52 PM.. |
09-17-2022, 06:25 PM | #12 |
4492
Rep 7,535
In the US market…the LCI came with the 2016 model year (build date was sometime in 2015 which is what confuses many with the LCI being 2015).
The front exterior physical changes (which can be seen in the pics posted above) is: Front
Rear
Interior
The steering wheels changed prior to LCI…depending on what option pkg you had. In the US market, all 6 series had a 3 spoke sport steering wheel…its just that there were different versions:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-17-2022 at 06:53 PM.. |
10-11-2022, 10:40 PM | #13 | |
117
Rep 248
The best advice I can give you is buy a post 2012 650. It will have the N63 TU ( technical update) V8. Get a qualified PPI done and check the service history to make sure it’s been serviced regularly. I’ve had my 2015 LCI F13 650 coupe for close to 5 years now and have never had an issue. It’s serviced every 12 months regardless of klms driven I only use premium top grade petrol. The car is delightful and I love it now as much as the day I bought it. Gosh they look the business don’t they ! |
