08-01-2022, 11:52 PM | #1 |
110
Rep 343
BM3 Stage 2 Supporting Mods
Hi all,
Have a F80 M3 2018 w 30k miles, planning to run stage 2 on 93 with BM3 once crank hub is done. Any supporting mods/upgrades worth looking into? Currently have upgraded charge pipes, intakes and catless DPs, and will get new spark plugs (probably done with the CH). Was looking at top mounted intercooler, heat exchanger, oiler cooler, mosselman thermostat, etc. Don't plan on tracking it, it'll be more for daily road use. Thanks! Last edited by Pewtinn; 08-02-2022 at 12:10 AM.. |
08-02-2022, 12:17 AM | #2 |
2897
Rep 3,729
Just the heat exchanger will do.
Everything else you listed is unnecessary for a street car. Mosselman thermostat keeps the engine oil too cool. By letting the car run up to temperature in sport mode (226f), you burn off water in the oil and extend the life of the oil.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
Pewtinn109.50 |
08-06-2022, 09:08 PM | #3 | |
110
Rep 343
08-06-2022, 09:10 PM | #4 | ||
2897
Rep 3,729
You could also get a fuel filter kit from Bend Calibration. It's a good safety item to have to avoid killing injectors from bad ethanol.
08-06-2022, 09:21 PM | #5 | |
110
Rep 343
Also a few questions about the flex fuel kit if you didn't mind - 1. In the PTF site, should I be getting the 'include flex fuel sensor' option? 2. If I did my research correctly, you fire up Multimap (stage 2 for me), and it will automatically adjust to the E mix, whether I have full 93 octane or partial E? Last edited by Pewtinn; 08-06-2022 at 10:11 PM.. |
08-06-2022, 11:45 PM | #6 | ||
2897
Rep 3,729
1) Yes 2) Correct
Pewtinn109.50 |
