06-21-2022, 10:55 AM | #1 |
Rep 26
New exhaust, diffuser, and paint correction
Just picked up my 2012 650i M-Sport Coupe 6-Speed after having a little work done on it. I loved the look of the carbon fiber rear diffusers, and wanted a little louder of an exhaust. Big thanks to DerBosewicht and skilz4u2nv who helped point me in the right direction in terms of getting it done right.
I started by purchasing the M6 Lower Cover so I would be able to fit the CF diffuser, along with CF exhaust tips and the 3-piece diffuser from eBay. I took the 6 to a local exhaust shop who cut out the exhaust and welded in stainless steel pipes to get the tips to fit properly. The guy at the exhaust shop was very helpful, and they basically were able to get the lower cover on to ensure the fitment was good. His brother happens to be a BMW enthusiast who works at a paint/repair shop, so the next step was bringing everything to his shop. I had the lower cover painted, 2 tow-hook covers (which were only primed) painted, touch up paint on the front bumper/hood/grill, and then the CF diffuser, trunk spoiler, and mirror caps all sanded and clear coated (looks so much better/deeper, and won't yellow in the sun). I also had them wet sand the hood, roof, and trunk lid to try to get rid of the etching. They also fixed a few dents on the passenger side before installing the rear diffuser. The fitment on the diffuser is not perfect, but it was a cheapo from eBay so I was expecting that to be the case. I had spent an absurd amount of time detailing the car when I first purchased it, but given it had spent quite a bit of time outside in FL with the previous owner, the paint had deep etching/water spots that I simply could not get through, and wasn't willing to try wet sanding myself. Even after wet sand/buff/polish some defects are still present, but it was not worth the cost to do a full respray on all the affected areas at this time. The attached pics more or less show the progress on the paint as I was doing my detail (and the etching I couldn't get through), the lower cover being installed, and then how it looks today. The last 2 pics are out of order, but show what the front looked like prior to the touch-up. There is still some work to be done, but love how it looks and sounds now! I'll try to upload a cold-start video later. |
06-21-2022, 07:04 PM | #2 |
1205
Rep 2,918
So it's a manual? Pretty rare. I got over my fear of wet sanding and do it all myself now. But letting experienced detailers handle it is probably nice. How do you get in it with it parked that close to the SUV?
06-21-2022, 07:28 PM | #3 |
16
Rep 42
I've been eyeing this project for a while. Did you just cut the square tips off like Skilz did or did you have to cut further back?
Also do you have a link for the tips? From what I've read the outlet size is different for the 650 vs m6 mufflers |
06-22-2022, 09:06 AM | #4 | |
Rep 26
And I get in very carefully! I always back in and leave enough room for the driver, any passengers just get in outside the garage. |
06-22-2022, 09:18 AM | #5 | |
Rep 26
In the end I'm glad I went with the full muffler delete. It was really loud/droney on the drive home, but seems to have found a balance now and sounds great without too much drone. I'm not sure if I'm allowed to link directly to ebay - but if you search "2PCS Glossy Black Carbon Fiber Exhaust Tip For M Performance BMW Universal Pipes" that is what I went with. 2.5" inlet, 3.5" outlet. I heard that there is a difference in the mufflers as well, and I think the angle of the pipes to the tips on the 650 play a part in that (though again, it may be possible with a different set of tips). |
J_ONeill16.00 |
06-22-2022, 09:34 AM | #6 |
Rep 26
Here is a vid of the cold start: https://www.youtube.com/shorts/9MWtSMiuQ5Y
06-23-2022, 06:06 AM | #7 |
Rep 3
Hi Sleepybear,
Car looks great. I have 2 questions... - I must have the M6 Lower Cover in order to install the rear diffuser? -Will the stock exhaust ( rectangle tip ) works with your new rear diffuser? Thanks |
06-24-2022, 09:43 AM | #10 | |
Rep 26
The stock exhaust won't work with the new diffuser, it just wouldn't fit over it. |
