06-17-2022, 09:34 AM | #1 |
Rep 7
X5 Leather Dash Peeling
Hello,
I have a 2016 X5 with 52,000 miles and have just found that the leather dash is peeling away near the windshield. Please see the attached pictures. Has anyone else had this issue and if so, what have you done about it? I believe this occurs from the sun causing the leather to shrink and pull away from the backing material. I will be using a sunshade in the windshield to hopefully prevent it from getting worse. Has anyone here taken out their dash for repair or replacement? Thanks. |
06-17-2022, 04:36 PM | #2 |
522
Rep 629
Have the same problem on our 2nd hand F15. As you surmised, this happens when owners park the car in direct sun, without a sunshade, and without venting the roof and/or windows. Shrinks the dash leather.
A sunshade has 100% stopped any additional shrinkage or damage on ours. And we live in South Texas with usually many 100+ degree days during summer. Also, we condition the leather to keep it moist, probably also helps. As far as fixing it, only removing the dash and having it recovered is likely to do the job. An upholsterer might be able to restretch and then glue the leather... but I'm not sure. It would be a time consuming job for you to take it out to bring to them, and cost prohibitive to have them take it out and do the work. |
06-18-2022, 02:43 PM | #4 | |
522
Rep 629
We use the BMW leather conditioner with UV (specifically get the one with UV) protectant. Kinda pricey but it seems every time we're out of it, it's easiest to go to the dealer because we need it. I've heard that it's the same stuff as the Sonax just rebranded as BMW but have no confirmation of that. |
08-01-2022, 11:56 AM | #6 |
Slower traffic keep right.
66
Rep 145
This has happened to mine as well. I love my X5 so much but can't unsee this after I first noticed it. I have always kept a shade on mine but noticed water on the inside of the glass after my X5 sat for a few months outdoors without being used. Not sure if it was from that or just the insane heat inside the vehicle when just sitting. I've started driving it more now and would love to have this fixed as it's getting worse. Has anyone actually paid to have this repaired/replaced?
Current: 2022 Tesla Model Y Performance (my daily driver) - 2014 X5 35d M-Sport in Carbon Black Metallic (for towing) - 2018 M4 ZCP (track fun) - 2006 Z4 M Roadster (topless fun)
Past: 2021 Tesla Model Y Long Range - 2011 X5 50i Sport - 2006 750Li Sport - 2003 M3 Convertible - 2001 X5 4.4i Sport - 1999 Z3 Roadster 2.8 |
JML19990.00 |
08-01-2022, 02:38 PM | #7 |
Rep 7
Sorry to hear about your issue. I contemplated selling the car after seeing this lol. I may try placing a black vinyl strip from Joanne Fabrics. Not sure it could look much worse than it does now.
08-01-2022, 02:49 PM | #8 |
66
Rep 145
I've also been thinking about something to make it black so it's not as noticeable. At least you don't have HUD. Mine is travelling around it, now. If you come up with something, please share a pic. You're right though... can't look much worse. I still love the car and want to keep it. Just needs some botox.
08-01-2022, 04:41 PM | #9 |
522
Rep 629
We're still living with it and no change on ours. It looks slightly better than what you posted OP. Fortunately had not spread to our HUD area.
There are only 3 options unfortunately. Remove the glass and have an upholsterer try to stretch/tuck the current leather along with injecting new adhesive through the windshield opening. Remove the dash from the X5 and take it to a shop for fixing or rewrapping. Buy a new dash/used dash that doesn't have the issue and fit that. All of the possible options are extremely costly (or time consuming) obviously with the most affordable being removing the dash yourself and installing a good used one (usually runs about $750 on Ebay). That said... I'd never buy an X5 without the extended leather dash. Our E70 X5 has it too (but without any damage) and just makes any vehicle feel like it's punching in a higher luxury class. |
08-05-2022, 02:30 PM | #10 |
856
Rep 590
Drives: F15 X5 50i, G30 M550i, iX 50i
I also have a 2016 X5 (about 120k miles). Same issue. Replaced my windshield last month and while the windshield was out, I just covered it up with some black electrical tape. Mine was only about 1/2" at the widest part so that worked. Yours looks a bit wider so...honestly if you can find a cheap fix and you can live with it... I'm ok with mine, I don't really notice it at all anymore.
12-14-2022, 03:23 PM | #13 | |
1368
Rep 1,532
This is what I'd do: E30 convertibles have a similar issue on the top of the rear seat, the leather shrinks and seam splits. Here's what I'd do (and what I've done on the e30): Use a fine brush or dauber to flow a deep black dye into the opening that's uncovered.. You'll reduce the appearance by 90%+ for less than 1% the cost of any other option. I'd be super wary of replacing the dash in the F15, regardless of who does the work. Seems like a good way to get a bunch of rattles.
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6 |
05-12-2023, 09:15 PM | #15 |
11577
Rep 11,141
It's for this exact reason I didn't opt for a leather dash on my G05. My F15 had it, and although it looked nice, extreme temperatures and leather dashes just don't work.
05-13-2023, 02:22 AM | #16 |
27
Rep 76
I've had mine retimmed by an auto upholsterer successfully, was about $2.5K AUD from memory. Took a few days to do as they need to remove the whole dash which is a decent job.
05-13-2023, 07:24 AM | #17 | ||
17
Rep 22
Ty for response. |
P111576.50 |
05-14-2023, 06:15 AM | #18 |
27
Rep 76
When you do find someone, ensure they take care with the ambient lighting as my place stuffed it up first time around due to it being the area where they remove the dash. Had to take it back for them to fix it up.
08-15-2023, 02:53 PM | #20 |
17
Rep 22
Did a DIY cheap fix on mine recently. I could see the white reflecting off of the windshield while driving was driving me nuts.
Ordered this: https://www.amazon.com/dp/B095XZQ56B...roduct_details I cut a piece off of the roll and used a trim tool to mark the outline I'll eventually try and stretch the leather back out and glue it down to make it smooth again around the edges but this satisfies me for now. Took me a couple hours, was a real pain in the butt and had to walk away a couple times. |
08-16-2023, 07:39 PM | #22 |
365
Rep 1,033
