04-18-2022, 12:01 PM | #1 |
13
Rep 50
Misfire impairing exhaust emission on all 8 cylinders
Hi,
First is it normal to have misfires & a CEL after 2 months on all cylinders if we replace an OEM exhaust by an IPE F1 front pipe with sport cats + IPE F1 x pipe + valvetronic mufflers ? I have a rough idle at cold ONLY, there is no more issue when i drive the car & when i start again also, it does at cold uniquely. No loss of power or performance, the OEM exhaust is re installed and those codes which are hard to solve appears always. Any help would be appreciated. 2B4E Misfire impairing exhaust emission at several cylinders 2B42, 2B43 etc to 2B49. I had also just one time the 27B1 and it never reappeared. - Last edited by Black.m3; 04-19-2022 at 09:22 PM.. |
04-27-2022, 06:45 PM | #3 |
3910
Rep 4,174
Check the obvious stuff? Ground strap, exhaust ring gaskets. If you already have the stock exhaust back on the car, clear the codes and try driving around without the intake plenum. Simultaneous 8 cylinder misfire is normally an intake-side issue, maybe an air leak.
DrFerry6730.00 |
04-27-2022, 08:01 PM | #4 | |
13
Rep 50
We made a smoke test in the intake, we haven’t seen an air leak somewhere.. Last edited by Black.m3; 04-27-2022 at 08:06 PM.. |
DrFerry6730.00 |
04-28-2022, 05:15 AM | #5 |
3910
Rep 4,174
Drive it without the plenum. If misfires stop at least you know its somewhere in the plenum/intake.
Smoke test are not accurate. When I had a plenum air leak, I smoke tested it 3x and water tested it 1x. Came out OK. Later found the leak happened only when it was under vacuum. |
04-29-2022, 07:48 PM | #6 | |
13
Rep 50
Because i putted back the oem exhaust and i still have these issues.. |
DrFerry6730.00 |
04-29-2022, 08:09 PM | #7 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Possibly a bad primary 02 sensor and/or weak battery. At rest the battery voltage should read 13.3V. IF it is low (~12.6V) then strange emissions codes may happen, the clock will also start to run slowly and other odd codes can appear.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
Black.m313.00 ///M Power-Belgium63943.50 |
04-29-2022, 08:31 PM | #8 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
04-29-2022, 08:32 PM | #9 | |
13
Rep 50
But the car starts with just a rough idle, and i can drive it normal after, and going faster there isn't a issue. So the issue isn't from the exhaust system at first ? Btw i changed the O2 sensor without a reset of adaptations, i still have the issue. I ll do it soon. |
DrFerry6730.00 |
04-29-2022, 08:41 PM | #10 | ||
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
The exhaust system might have caused some codes to be retained in the DME/ECU memory. Charge the battery, then clear the codes, make sure all 4 O2 sensors are installed and connected securely.
04-29-2022, 08:54 PM | #11 | |||
13
Rep 50
Unfortunately the M3 E92 has a special repair system when we change some parts of it.. not like the E46. |
DrFerry6730.00 |
04-29-2022, 09:04 PM | #12 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
AGM means "Advanced Glass Matt". It is a newer technology than traditional lead acid batteries. IF your car has start-stop that system puts stress and strain on the battery, alternator and starter motor. Consequently, I recommend you install and use the correct type of battery your came with from the factory and that is AGM. Your Dealership might be able to code (register) the specs for an non AGM battery BUT I'm uncertain of that since ISTA may not have non OEM choices for battery registration specs.
I believe Start-Stop can be turned off using the small switch which is part of the start-stop bezel.
04-29-2022, 09:15 PM | #13 | |
13
Rep 50
DrFerry6730.00 |
04-30-2022, 12:43 AM | #14 |
3910
Rep 4,174
Many people have replaced the AGM batt with normal lead-acid with no issues. It should not be the cause for your problems. Forgetting to code a new batt also will not cause misfires
Removing your cats without a tune will cause emissions CEL but should not cause misfires. Again, remove your plenum and drive it and see if the misfires still occur. |
04-30-2022, 08:00 AM | #15 | ||
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Perhaps I misunderstood. I thought he wasn't actually getting any misfires. He mentioned he has no loss of power or performance but merely getting the codes thrown. Hence, I thought it might be a low voltage battery issue. Forgetting to code a new battery may cause the battery not to be charged properly and low battery voltage can cause all sorts of gremlins. Agreed a tune is needed to remove the CEL if or when the Cats are removed. Good idea to run it and drive it without the plenum and see if the codes go away.
04-30-2022, 10:08 AM | #16 | |||
13
Rep 50
I never made a tune with the IPE F1, and i installed the front pipe with sport cats + x pipe which according to IPE it should not trigger the CEL, and doesn't need a tune only if you go cat-bypass (catless) And i putted back oem exhaust with always the same issue. So to go step by step, for IPE my issue isn't related to the installation of the exhaust and for them it's a fuel or engine verification.. But what it's strange is that i had these fault codes after 2 months from the moment i installed the exhaust. I never had these codes before to install the exhaust system, but if I'm not mistaken I noticed a slight irregular idle sometimes at cold start without codes or CEL before the installation of the IPE. |
06-08-2022, 04:05 PM | #17 | ||
316
Rep 204
Drives: M3 Coupe e92 competition packa
the same problem( - https://www.m3post.com/forums/showthread.php?t=800514
as I found at forum , there are 3 or 2 variants of solving this 1. Quote:
3. Fuel Tank Vent Valve 13907838281 https://www.m3post.com/forums/showthread.php?t=1148243 BMW 13907838281 As for me, the most true for your situation is variant 2 I have the same problem, with my friend's car, and we will check all this variants |
DrFerry6730.00 |
