02-24-2022, 10:52 PM | #1 |
160
Rep 171
Drives: 2015 BMW M3
Continuous Breather Valve Failure
What's up cats and kittens,
I'm looking to hopefully get some guidance on saving money and time. What I mean by that is that I've replaced my valve cover twice in the last 6 months due to PCV valve failure (whistling when at idle coming from engine bay). I've become a fucking pro at replacing valve covers on the S55 at this point. My dilemma is that I'm running a custom Full E85 tune on my F80, making mid to high 500s. I can only assume this is causing excessive pressure in the crankcase, causing the breather valve to fuck itself. I've seen rocket scientists drill a hole in the center of the valve as if it'll solve all their problems, mechanical and mental. I just can't see myself half-assing anything on this car. Ive been thinking of installing an AOS to mitigate oil buildup, or even looked into a Vargas valve cover, but I'm not keen on random aftermarket parts. Let me know what you guys have in mind that can help. |
02-25-2022, 09:49 AM | #2 |
5494
Rep 5,179
Sorry that I can't speak to why you're getting too much pressure in the case. It doesn't sound like your engine is built too heavy. Hopefully one of our mechanics here can chime in on it.
As for the OCC/AWS and the VTT valve cover, those aren't the answer… 1) The VTT cover has the front breather holes right near the VANOS chain and gear so lots of oil spray gets sucked into the PCV tube. I almost bought one but my mechanic had recent problems, and VTT said it's just like that. No help from VTT as usual. My mechanic said if you do install the VTT cover you'd definitely need a full AWS plumbed in to catch all that spray. 2) On the OCC topic, it doesn't change the pressure, just gives a place for any vapor to "catch". Gasoline makes little catch, but running E85 makes quite a bit. The only benefit I've seen from OCC so far is that it slows the alcohol dilution of engine oil when running E85.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
McBobby Jr212.00 |
02-25-2022, 02:13 PM | #3 |
299
Rep 585
Did you happen to replace the breather hose at the front? I replaced my valve cover and had an immediate failure of the new one. Replaced it again and replaced the cracked breather hose and it's been good since then.
Vandaljimenez159.50 |
03-01-2022, 12:55 PM | #4 | |
160
Rep 171
Drives: 2015 BMW M3
I might just replace the hose just because and install the OCC since I'm on Full E85 as you said. It only makes sense Anybodys got input on drilling a hole on the breather valve? |
