01-27-2022, 04:48 PM | #1 |
232
Rep 337
Staggered set up on xdrive?
Read a lot about staggered rims on xdrive vehicle. Some people state that it damages xdrive components, others say that it’s ok. I have staggered wheels on my x5 with no issues. But what about 650i xdrive? Please share your opinions and experience)
01-27-2022, 06:08 PM | #2 |
1207
Rep 2,919
Basically the same system. They key is diameter - same issue with replacing one tire. The overall diameter of the four wheels should be within a certain tolerance. I don't know what BMW's is, but the most I've seen is 4/32" (1/8") - at least on the same axle. Not sure about between axles - it's been too long since I read up on it. But the damage must be very slow to occur because I've never seen a post about actual damage - just theoretical damage.
DenBel232.00 |
01-27-2022, 11:07 PM | #3 |
Customize Everything!
44
Rep 279
Staggered setups do not screw with with Xdrive provided your wheel diameter is not so drastic from original spec that rotational diameter tolerance does not exceed 1%. At least that was my understanding from BMW since there are BMW specs that offered stock staggered setups.
The below link can help. You determine rolling diameter and proper offsets. Plug in your current set up and desired setup to check compatibility. https://tiresize.com/wheel-offset-calculator/ |
DenBel232.00 |
01-28-2022, 01:22 AM | #4 |
252
Rep 631
Drives: 2014 M6 Grand Coupe CP
As long as the outside diameter (and circumference) are the same, the width does not matter. If there is a diametrical difference either on on the same axle on between front and back are different it WILL contribute to accelerated wear of the drive train components, particularly the clutches. The larger the difference the larger the wear increase. Obviously there is some tolerance since tire pressure differences also change the rolling diameter.
The exception would be the new 4wd systems that are designed to be able to run on rear wheel drive only (M-cars).
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
DenBel232.00 |
01-28-2022, 10:10 AM | #5 | |
4504
Rep 7,548
Just like your X5...the 6 series owners manual lists BMW's recommended staggered wheel/tire sizes in the owners manual. If the AWD 6 series weren't designed to handle staggered wheel/tires...then I doubt BMW would recommend them in the manual. As mentioned already...it's about staying within spec of overall rolling circumference that is important. 245/40/19 (front)
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
01-28-2022, 10:19 AM | #6 | |
232
Rep 337
01-28-2022, 01:41 PM | #8 |
252
Rep 631
If you look at tire rack, in the spec section, they have the tire revolution per mile. the 275/30/20 are 784 per mile and the 245/35/20 are 777 revs per mile which is just about 1% difference. That gives a good guideline if you want to choose other sizes.
DenBel232.00 |
01-28-2022, 09:25 PM | #10 |
95
Rep 284
To take it yet one step further, the tire manufacturer also lists the diameter of each tire that they produce. You will need to go to their website and dig a little, but it's there. With these figures you can calculate and find a combination that works within the 1%. I just recently did this with Michelin.
BTW, I am running style 373, 20" in 245/35 and 285/30, which is also an option listed with Tire Rack. L |
DenBel232.00 |
01-28-2022, 11:02 PM | #11 | |
232
Rep 337
EDIT: the rears are the issue because of the offset. Last edited by DenBel; 01-28-2022 at 11:11 PM.. |
01-30-2022, 06:52 PM | #12 |
Mindys6
Rep 11
During an emergency i was forced to put a staggered setup outside of stated tolerances and blew up my front drive. Was a 12k repair. long story. ill never attempt it again. a flatbed tow truck and a night in a hotel is cheaper
02-08-2022, 12:29 PM | #13 |
62
Rep 242
Closest I got is 235/35 front and 275/30 rear.
235/35/20 gives a 26.476 diameter and 83.177 circumference. 275/30/20 gives a 26.496 diameter and 83.239 circumference. Difference is very minor. Definitely less than 1%. 99.92% similar. |
02-14-2022, 08:13 AM | #14 |
32
Rep 121
Reality of different tires and diameters can be something else what those size tables are showing. Front and back different camber angles has own affect.
