01-20-2022, 11:26 PM | #1 |
330
Rep 1,158
Drives: 2011 BMW M3 2020 BMW M5C
List of one time use bolts?
I saw the comprehensive list of torque specs, is there a similar list or a supplement of TTY or one time use bolts on the car?
Planning to do subframe bushing and driveshaft swap, wanted to see if I should buy a new set of hardware for it or will it be fine to reuse. Thanks.
Interlagos Blue/Speed Cloth | BayOptiks DTM Headlights | Alpine Stage 2 | KW Clubsport | Resonated X-Pipe | Eisenmann Race | StopTech BBK | TE37SL | YFCM CF Driveshaft | Hotchkis F/R Sways | F/R Endlinks | Turner Control Arms and Front Tension Bushings | Powerflex Diff Bushings | Turner Solid Subframe Bushings | MS Underdrive Pulley and Intake | Alpine DCT Tune | Karbonius Intake | Carbon Roof (TBD)
01-20-2022, 11:53 PM | #2 |
3085
Rep 2,747
I recently had a bolt snap on the rear right upper guide rod and it made a bit of a mess of my half shaft. Safe to say I went back and replaced all the arms and hardware. You should replace them.
9ers
01-21-2022, 08:21 AM | #3 |
1051
Rep 836
Drives: Jerez E92 M3 ZCP "12"
I highly recommend since your subframe will be dropped, you are better off just getting all new bolts and washer...peace of mind. I purchased the bolts from FCP Euro, in the years to come,,,lifetime warranty will cover it
01-21-2022, 12:18 PM | #4 |
3085
Rep 2,747
Here's a list of all the stuff I ordered which included new subframe bolts, all new arm bolts, diff bolts. Also a cheat sheet I found for torque values almost complete. Rear only
9ers
Ubersmooth315.50 jvictormp907.50 |
01-21-2022, 03:13 PM | #5 |
336
Rep 724
The bolts for the driveshaft are also one time use. However, the factory balances the driveshaft & differential. Depending on the year it may only have special washers (older) but some years have bolts with different threaded lengths, which are color coded. Unfortunately the heat shield makes this junction difficult to inspect ahead of time. It is likely that washers could be reused. It is likely a good idea to figure out if any of your bolts are a different color before you order the hardware.
This thread describes the issue. https://www.m3post.com/forums/showthread.php?t=1231461 |
