10-28-2021, 03:35 PM | #1 |
Rep 77
EDC delete
Thoughts on an EDC programming delete v a hard ware delete? Any references and reviews for a programmer? Getting a coilover set up installed next week..
Thanks in advance for sharing. |
10-28-2021, 05:37 PM | #2 | |
473
Rep 468
I had Alex @ Alpine code out my EDC while also getting euro MDM and a few other things. Was a reasonable price and cheaper/easier than an emulator. Unplugging the EDC module takes less than 10 minutes and only requires a screwdriver (if I remember correctly.) You can sell the edc module for 100-200 bucks or keep it in the event you want to go back to an edc setup.
10 E90 M3 /// Dinan Intake, X Pipe, Exhaust, Underdrive, 3.62 Diff, Coilovers, Alpine e85 Tune - sold
16 F80 M3 /// MaxPSI 4 Pin, DP, CP, SL Mid-Pipe, TMIC, KW HAS, EU5's, AB Performance Flex Tuned |
BOOF-M34451.50 |
10-29-2021, 12:04 AM | #3 | |
214
Rep 161
Drives: slow
The correct way is to code the car and (important) then unplug the module. I wouldn’t even bother with an emulator. You will be pulling the same panels regardless. |
