10-23-2021, 10:35 PM | #1 |
146
Rep 234
Max oil warning worries
About 3 or so days ago, I decided to top up my M3's oil, and I stupidly put too much in, I wouldn't imagine I put way too much in, but enough to give me an 'oil level too high' message. After a quick search of the effects of high oil level, I am extremely paranoid as I put quite a bit of high mileage and hard driving the day after I overfilled it (didn't check the oil until after). This morning, I had to drive the car, I went to start it (got very cold overnight), and on cold start it started with an extremely rough idle, and eventually bogged out/stalled. I know the simple and only solution is to simply drain a bit of oil, but I have been without an access to a floor jack or an oil extractor pump for the last few days. Any help, or opinions would be greatly appreciated. Thank you.
10-23-2021, 11:20 PM | #2 |
3996
Rep 3,415
You answered it. Loosen the front drain plug and let some oil out.
Not a Doctor, those are just my initials.
10-24-2021, 08:44 PM | #5 |
165
Rep 126
It shouldn't be an issue whatsoever.
People that build the s65 race engines recommend to race this engines with half a quart over the max level. I raced my car with the oil slightly higher the top level with no issues. It was not even smoking… Unless you added like a quart or more over the top, I wouldn't be concerned. And it wouldn't cause the rough idle. It must be something else. |
10-24-2021, 09:10 PM | #6 | |
3996
Rep 3,415
OP - the car is telling you it's too much oil. You can listen to random advice on the internet or simply drain a little out.
SnohoRaptor534.50 bmwm3fanatic146.00 |
