10-08-2021, 09:21 PM | #1 |
162
Rep 687
If you run eventuri can you please check something?
Hi, standing in front of your car open the bonnet, and check if the maf sensor plug on rhs has rubbed through the fuel line under the braiding
Mine has rubbed halfway through There is no way to orientate it to not rub Its low pressure line that supplied hpfp |
10-09-2021, 02:45 PM | #2 |
218
Rep 254
Mines very very very close. You can orientate it so it barely touches. Im sure I slightly bent the pipe or a bracket or something to move that fuel pipe a couple of millimetres to make enough difference.
10-09-2021, 04:53 PM | #3 |
162
Rep 687
Thanks, i have also moved mine slightly and shave bottom of connector off to give clearance
Not really happy with it they just had to make maf housing sit few degrees more in one direction and clears no drama The solid pipe is stainless and cant be bent no room to work |
10-10-2021, 01:35 AM | #4 | |
580
Rep 486
I believe the MAF connector is positioned this way to not interfere with the hood. If it's too steep, it will stick out to far and touch the hood on the inside. Anyway, it's a nuisance and I will keep an eye on this! |
10-10-2021, 06:00 AM | #5 |
162
Rep 687
It has more clearance from hood
I emailed evolve and their reply was they wouldnt have designed it that way Im sorry but it wasnt thought out very well and definitely is asking for trouble |
