10-02-2021, 10:57 PM | #1 |
Lord Scrip
1820
Rep 3,016
Drives: 2011 M3 Coupe
Feels like running over a series of road reflectors (SOLVED)
Hey everyone,
Looking for opinions/ideas with a recent issue I've noticed. A little background…..Just replaced both EGR valves as well as the y-hose. While there I did spark plugs. No more bank 1 secondary air errors. It's been over 600 miles & 2 weeks since this work.This morning I went for a drive and when giving it full throttle in 1st & second there is a period around 2k to 3k in both gears where it feels like the car is running over a series of closely spaced road reflectors like those on a solid white or yellow line. 3rd gear and up do not produce this if on hard throttle. No errors, no loss of power, no weird shifts. It will happen in any drive mode S2-S5. I can't tell if it's a tranny, drive shaft or rear end vibration unfortunately. Any ideas, thoughts or experiences is what I am seeking.
10-04-2021, 05:11 PM | #3 | |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium63939.00 |
10-06-2021, 07:45 PM | #4 |
Lord Scrip
1820
Rep 3,016
I tried but there isn't enough audible noise to hear over the motor. It's definitely felt though. Besides road reflectors spaced out like 6" from each other it reminds me of the traction control kicking in kinda.
10-06-2021, 07:47 PM | #5 | ||
Lord Scrip
1820
Rep 3,016
10-07-2021, 11:10 AM | #6 | |||
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
10-07-2021, 11:08 PM | #8 |
Lord Scrip
1820
Rep 3,016
Everything is assembled correctly. I was very meticulous with every part. I have no error codes present in the car. To do the EGR valves it's the removal of the plenum, rear engine hook, half the wiring harness (drivers side) and the vacuum pump. I replaced both valves, gaskets, securing nuts, heat shied bolts and the Y-hose. Also did the spark plugs and I torqued them to spec. I took pictures of things at each step to ensure everything went back correctly the first time. I've done the plugs 5 times now and I've never had an issue with ignition afterwards.
DrFerry6730.00 |
10-07-2021, 11:10 PM | #9 | ||||
Lord Scrip
1820
Rep 3,016
10-08-2021, 11:17 AM | #10 | |||||
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
10-08-2021, 09:14 PM | #11 |
Lord Scrip
1820
Rep 3,016
So it's not violent but it's noticeable. I feel like all the potential causes you mention would draw an error from the DME. I'm going to try and inspect my motor mounts this weekend. I looked under the car again and there are no fluid leaks from diff or trans nor signs of wear. Because it's only between 2&3k in 1st and 2nd only I think it may be worn mounts but I'm going to plug in and keep reading for errors. Thanks for all the ideas man. When I get it figured out I'll report back here.
DrFerry6730.00 |
10-10-2021, 04:44 PM | #12 |
2760
Rep 5,483
Broken wires and ground issues don't always throw codes. You'll have handled a bunch of harness that is at minimum 10 years old and been heat cycled thousands of times. That's what I mean by starting there. The ignition cables are designed for handling as part of the service procedure...some of them are definitely not and don't have a ton of tolerance for twisting bending and such.
All that being said, yeah I'd get some known good coils on there. They don't last forever
10-10-2021, 07:59 PM | #13 | ||
Lord Scrip
1820
Rep 3,016
10-14-2021, 11:59 PM | #14 |
Lord Scrip
1820
Rep 3,016
Found my issue! Both guibos are good but my carrier bearing is shot. Makes sense as I couldn't differentiate where the vibration was coming from (front, middle or back of drive train). No cracks at all on the front or back guibos so the huge crack in this carrier bearing bushing is my culprit. (2nd Pic attached). Question for those who read this……is this blow by/leak on my exhaust? (1st pic attached) the black marks look like gas escape points to me. Let me know if you have time.
DrFerry6730.00 |
10-15-2021, 12:54 AM | #15 |
4482
Rep 7,121
Wow this forum eventually solves even the strangest issues om this car. Bloody good job done Scrippy!
Ps. All good on the dent and mad people side..? |
10-15-2021, 02:02 AM | #16 |
Lord Scrip
1820
Rep 3,016
Hahaaa, I didn't solve it myself. There are like 6 prior threads that helped. I was just lazy pulling parts off. If I had a lift my post would have been "informational" instead of another "help" thread. Now I'm compiling my rebuild kit. All hardware will probably be replaced. I see a shim and a centering ring annnnnd… The guibo looks good but I'm here already so naturally thats gotta be replaced lol. Same thing for the trans mounts. It's looking like a $500 thing to do it right so far. I'm trying to suppress my OCD to areas or sections, otherwise it would end up being an underside restore somehow. Purl is 11 years old now.
DrFerry6730.00 |
10-19-2021, 08:46 AM | #17 | |
2760
Rep 5,483
Coils going bad don't always throw codes but misfire codes are usually way before any noticeable drivability issues. I'm just talking keeping the car in top shape, but without a misfire code they're probably fine Yeah that looks like a little bit of leakage, is there also black on the clamps? That'd be the giveaway
10-19-2021, 08:45 PM | #18 | ||
Lord Scrip
1820
Rep 3,016
