08-27-2021, 04:05 PM | #1 |
23
Rep 28
Weird knocking/snapping noise?
I'm baffled by an obscure noise my car has been making over the past few months. It doesn't seem to be getting worse, but the best I can describe it is as a knock sound that happens under weird circumstances - more reasons as to why it's throwing me off.
Occasionally, if the car has sat for a while (a day or two) I'll hear it right as the engine turns over there is a singular knock noise. It doesn't sound like the engine itself, rather something in the engine bay hitting something. Almost like a ball peen hammer on a thick steel plate. More often, however, if the car is changing direction rapidly around a tight corner (usually a right turn) or over a big bump I'll hear a nearly identical sound although coming from what seems like the passenger front wheel. It also seems to happen a little less frequently when the car comes to a harder stop, right as the car is stopping. Again, just a single knock noise. Mind you, this doesn't happen all the time and only enough to take note of. Also, everything else about how the car behaves perfectly normal. It's almost like something small and metal is loose somewhere, but I haven't located that and I can't be sure. This one's really making me want to pull my hair out so if anyone has any pointers please feel free to let me know. |
08-27-2021, 05:15 PM | #2 | |
64713
Rep 24,949
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
08-27-2021, 05:41 PM | #3 | ||
23
Rep 28
I'll add that I started to notice this after having my rod bearings and motor mounts changed, and I had the bimmer world dipstick put in during the service. The car currently has just over 73k miles. |
///M Power-Belgium64713.00 |
08-28-2021, 06:53 AM | #4 | |
64713
Rep 24,949
When the car sits for a few days ,most of us are having the clunk or rattle noise during the start up . The noise is vanos-gears related . But it won't hurt our S65 . Your other noise is probably suspension related .
08-28-2021, 07:11 AM | #5 |
924
Rep 938
Drives: E90 M3
How old are your engine mounts? Take off the drivers front tire and you can get a straight shot of the drivers side and check out the condition. Motor can be wiggling a bit if they're bad enough
08-28-2021, 12:27 PM | #6 |
64713
Rep 24,949
Read # 3
08-28-2021, 12:45 PM | #7 |
924
Rep 938
Drives: E90 M3
Ah, yeah, reading….. thanks!
09-17-2021, 06:59 PM | #8 | ||
23
Rep 28
https://youtube.com/shorts/bhvhSKDJ3nY?feature=share |
09-17-2021, 07:44 PM | #9 | |
64713
Rep 24,949
But your clunk noise is softer ..You shouldn't be worried .
