07-18-2021, 11:57 PM | #1 |
39
Rep 87
7 series seats same as 5 series seats?
Recently checked out a G30 LCI with the multi contour front seats. Didn’t like them as much as those in the X5/X7, which I found bigger and cushier. The massage function was also quite underwhelming if I’m being honest - maybe that made the seats harder too. Are the seats in the 7 the same as those 5? Do anyone of you have qualms with the current seats?
07-19-2021, 02:14 PM | #3 | |
4486
Rep 7,528
For example...I clicked on the base seat for a G11 750i and this is what was listed: https://www.realoem.com/bmw/enUS/par...&q=52107354590
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
KK22137.50 |
07-19-2021, 05:03 PM | #4 | |
39
Rep 87
07-20-2021, 09:31 PM | #5 | |
138
Rep 159
Totalled G12, Now in an A8
07-20-2021, 09:34 PM | #6 | |
138
Rep 159
07-25-2021, 07:09 PM | #7 |
"Salud"
13923
Rep 4,685
Drives: F01 & F15 / Mineral White
Hard as Seats in a car of this level and cost and purpose, is simply not right.
It appears BMW will finally address them with the next model. |
07-27-2021, 10:52 PM | #8 |
39
Rep 87
Hope so. 2016/the G11 was BMW’s first CLAR vehicle and they’ve released a new generation of CLAR cars (mainly SUVs) since then so hopefully the next 7 series will represent the sum of all lessons learned on that platform up to this point. Still can’t believe G11 customers had to wait until the 2020 LCI to experience a vehicle with appropriate levels of road noise for instance.
09-07-2021, 10:36 AM | #9 |
138
Rep 562
Is there any literature around this somewhere? I'm debating between a 530e and a 740e and I keep reading that the 530e is really quiet, meanwhile I've also read that the 7 LCI is becoming more quiet. Wondering if perhaps the 530 is a more insulated experience, since it's a newer design.
09-09-2021, 09:37 AM | #11 | |
39
Rep 87
Bear in mind that the LCI electrified model is the 745e. Also, if you're in the US, the quietest g12 models will be the 750i and m760i since those get now thicker acoustic glass (vs pre LCI) for the front, side, and rear windows. This will help with wind noise at highway speeds, road noise, and ambient noise. In other countries, I believe there is an acoustic glass package for other trims. |
09-09-2021, 04:39 PM | #12 |
1840
Rep 1,487
My single biggest complaint with my 2019 750 is the atrocious levels of road noise, especially when it's wet outside. Driving the car home from the dealership the first time I actually thought the drivers door wasn't closed all the way.
Add to that endless creaks and rattles from the dash area around the vents and hvac controls, the headliner, and rear drivers-side door. It was enough to drive me insane. It just seems to me that since this was their first attempt at the CLAR architecture, there were hella quality control issues they didn't have time to sort out, hence the reason why the LCI is so much quieter. Overall this car spoiled my relationship with BMW so badly that I am probably jumping ship to Porsche later this year. Somewhere along the line BMWNA forgot what "customer service" means.
Blessed Beyond Measure
09-09-2021, 08:43 PM | #13 | |
39
Rep 87
It seems like BMW used the first gen of the 7 as a bit of a CLAR experiment. It’s kind of strange to have to add sound deadening to a flagship later on but that was probably the result of a lot of complaints. The LCI 7 is also said to be less floaty than the pre LCI version, a common complaint. Overall it seems like the LCI is what the 7 was supposed to be. |
09-10-2021, 11:59 AM | #14 |
483
Rep 313
https://www.7post.com/forums/attachm...1&d=1631198274
So, can the wheel arch shielding and B pillar sound deadening be retrofitted to a pre LCI, as not aware of any other changes that would prevent it, and then next question part numbers and potential cost?
Current: 2018 BMW G11 740d MSport XDrive
Past: 2015 Audi 3.0tdi A8L, 2012 Audi 3.0tdi A8L, 2009 Audi 3.0tdi A8, 2005 Jaguar 4.2V8 XJL, 2000 Jaguar 4.0V8 XJL + many others |
