06-04-2021, 03:19 AM | #1 |
32
Rep 182
Software Update
Anyone know the final/latest integration software version that can be loaded into a pre-LCI M3 ?
Or can that version take the latest load? cheers |
06-20-2021, 05:13 AM | #4 |
182
Rep 357
That was my take, steering was better, diff punches straighter, dampers are better resolved (even in sport plus) and gearbox was smoother and traction control seemed more developed.
06-20-2021, 09:33 PM | #6 | |
26
Rep 133
If not done right you can brick your car and you will require at least a 40A+/13v power source plugged in (not your typical 5A trickle charger). The car draws up a lot of current while being flashed. |
06-22-2021, 03:25 AM | #7 |
182
Rep 357
It's fraught with danger if you're not familiar.
My advice would be to ask for the dealer or independent specialist to do it next time you're having an oil change or similar. It can be done in parallel and works out much cheaper because you're not blocking a bay just for flashing the iStep update. |
06-22-2021, 10:28 AM | #8 | |
19
Rep 83
I'm mainly after the full screen apple car play functionality and improvements in diff/EDC |
mfurse182.00 |
06-22-2021, 10:27 PM | #9 | ||
182
Rep 357
