05-08-2021, 05:34 PM | #1 |
299
Rep 542
0-60 times on the street.
My friend with a tuned DCT E92 M3 posted a nice 4.0 0-60mph, which naturally made me want to go beat it. I was able to pretty consistently post 3.91-3.93 on back roads. What have you all been able to do on the street?
Sakhir Orange F10 M5 | KW V3s | Dinan Swaybars | Turner Monoballs | Soul Exhaust | Mishimoto Oil Cooler
05-10-2021, 06:12 AM | #2 |
252
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
I haven't attempted any 0-60's in a long time. Partly due to the aggressive forces/stresses put on the car and tires. If I remember correctly, I was able to hit mid 4's? Bone stock with 6MT.
05-10-2021, 07:50 AM | #3 | |
299
Rep 542
I know MT got 3.7. I'm assuming they were on a prepped surface, so 0.2s loss for well-paved, but (likely) dusty rural farmland roads is probably right. Was hoping with PS4S instead of PSS and the seemingly better weight transfer of the KW V3s that I could at least break into the high 3.8s, though.
santamonica0070.00 |
05-11-2021, 05:36 AM | #4 | |
252
Rep 606
05-11-2021, 10:00 AM | #5 |
299
Rep 542
and if I break it, it is a lot cheaper to fix.
05-11-2021, 01:35 PM | #6 |
1158
Rep 545
Drives: 2015 M5 CP - 2022 M5 CS
My 0-60 times are embarrassing. Even with a 325 rear tire, the extra power from the mods blows the tires off. I’m sure I could do better with my throttle modulation but I never really hit it from a dig anymore.
05-11-2021, 02:36 PM | #7 |
299
Rep 542
I had a hard time initially when I was trying to bring RPMs up to "launch" it. I'd either bog it or spin too much. I then read some old thread on here about just punching the gas and that has worked quite well. Being I'm not tuned, I'd guess I was punching it to ~75-80% in 1st and then going full WOT as soon as it shifted to 2nd.
M5Rick60842.00 |
05-11-2021, 03:37 PM | #8 |
1158
Rep 545
When I first got the Dragy I tried everything from launch control to second gear starts.
The best I did was 4.4s iirc - and traction was definitely an issue! |
05-12-2021, 08:58 PM | #9 | |
171
Rep 349
Definitely not an easy car to launch cleanly in my experience. |
05-13-2021, 09:02 AM | #11 | |
299
Rep 542
I also have KW V3s, which supposedly improve weight transfer. It feels like that's true, but don't have any concrete evidence that it actually does or how much.
05-13-2021, 02:09 PM | #12 |
35
Rep 102
...Or go all the way and run Pilot Sport Cup 2s.
Like many Northerners, I have a summer and winter setup. Except in South Florida, we have 2 seasons, dry in the winter and wet in the summer. I run the Cup 2s on my winter wheels and PSSs(will replace with PS4Ss when they wear out) in the summer. The difference is immense. Once you get them warm, the Cup 2s feel like they're made of glue, whereas the PSS are constantly spinning. Like the Doctor said, you can still blow the tires off if you don't use a sensitive right foot, but the Cup 2s make a very noticeable difference. It should be mentioned that my Cup 2s are 305s vs 295s in the PSS, so it's not a 100% fair comparison. |
05-14-2021, 08:49 AM | #13 | |
35
Rep 102
If I lived in somewhere dry year round, I would run the Cup 2s all the time like the previous owner of my car did. |
M5Rick60842.00 |
05-14-2021, 09:01 AM | #14 | |
60842
Rep 19,783
05-14-2021, 12:41 PM | #16 |
60842
Rep 19,783
My old rear 295 PSS were about half worn and had a lot of skipping and screeching from launch getting nowhere.
A change to 305 pilot 4S's turned the car into something else with less screeching and more go and shortly after I changed the fronts to 4s also, very happy with these tyres without going Cup 2's. |
05-14-2021, 09:35 PM | #17 |
35
Rep 102
Sounds like you've had two very different experiences. Maybe the switch from 295s to 305s makes more of a difference than the PSS vs PS4S. It's hard to believe 1 little cm of rubber could make that much of a difference, but I guess it's possible. I'll share my thoughts with you guys when I switch to 305 PS4Ss.
05-15-2021, 01:54 AM | #18 | |
171
Rep 349
The PS4S definitely seem to get the most votes for all round road tyre on the F10 M5 though and will definitely be what I fit when the current tyres wear out. |
05-15-2021, 06:40 AM | #19 | |
60842
Rep 19,783
05-15-2021, 08:12 AM | #20 | |
299
Rep 542
I saw quite a significant increase in grip with new tires in the same size. I'd guess it was mostly just going from old, worn, and heat cycled tires to new ones, with the improvements from PSS to PS4S making up the rest. |
05-15-2021, 04:30 PM | #22 |
285
Rep 634
Traction seems to be the biggest issue with the F10.
I though punching the gass all the way down initiated "burn out mode", that's what my old E46 M3 SMGII did. I assumed the same on the F10 but I never tried. PSS vs PS4S Huge difference!!! My car had a set of 60% worn PSS when I got it and the car was stock 575hp, traction was a huge issue. Got a new set of PS4s and had very little traction issues before I put the stage II tune in, then it was just about the same as stock with PSS. Starting to get used to the rear getting loose past 60mph now Tire pressure will probably also be an issue, think you may need to go lower than recommended pressure to get more traction when setting a good time.
_____________________________
-14 Imola Red M5 Competition Pack (sold) -90 BMW 850i Supercharged -20 i3s -20 Ducati Diavel 1260s |
