BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
BPM
      10-20-2008, 05:19 AM   #1
dar2008
dar2008's Avatar
303
Drives: E93 M3 and E92 M3 Comp
Anyone done this mod on a DCT car?...
I'm planning to swap out the front ashtray for the sunglasses tray as described in this DIY thread...
http://www.e90post.com/forums/showthread.php?t=7049
Has anyone done this successfully on a DCT equipped car? Specifically, does the front centre console lift off in exactly the same way as described in the DIY thread?
Thanks in advance.
      10-20-2008, 05:27 AM   #2
Sticky
78
Drives: E92 Jerez DCT M3
That is really cool but don't think all sunglasses will fit, looks like they have to be relatively svelte.
      10-20-2008, 07:21 AM   #3
sg///M3
sg///M3's Avatar
Drives: 2008 M3 DCT
Thanks in advance.
Yes, install is the same. The console is a PITA to pry off. You actually have to use enough force that I was afraid I was going to break the trim piece.
      10-20-2008, 07:23 AM   #4
J08M3
J08M3's Avatar
285
Drives: 2011 M3 COUPE
My sunglasses fit. Great mod for me since I don't smoke. Mine's a 6MT though
      10-20-2008, 07:29 AM   #5
dar2008
dar2008's Avatar
303
This is exactly what's delaying my attempt. I had a look yesterday and found absolutely no movement when trying to pull up the centre console from around the DCT shifter.
Please reasure me that if I keep pulling, it will eventually give, and that it won't break in the process...
      10-20-2008, 07:46 AM   #6
sg///M3
sg///M3's Avatar
Drives: 2008 M3 DCT
Yeah, what I did was wrap a screwdriver in a cloth, jammed it in the seam of the trim, and just gently pried the piece up, working my way around the edges. Go slow so you don't damage your interior. It takes quite a bit of work. But the sunglasses holder is much more useful than the ash tray, IMHO.
      10-20-2008, 07:51 AM   #7
dar2008
dar2008's Avatar
303
That's great, so instead of pulling it up from the centre, I prise it up around the edge,... good idea about the screwdriver wrapped in a cloth. I'll give it a go next weekend, and am going to try to transfer the ambient lighting into the sunglasses tray.
Many thanks.
      10-20-2008, 10:09 AM   #8
mkoesel
Moderator
7512
Drives: No BMW for now
The downside is that you lose the power outlet, right?
      10-20-2008, 10:30 AM   #9
dar2008
dar2008's Avatar
303
True, but there is another under the armrest.
      10-20-2008, 10:41 AM   #10
booforty
booforty's Avatar
337
Drives: E92 M3
2008 E92 M3  [0.00]
Look forward to hearing how you get on and seeing the pics!
      10-20-2008, 10:53 AM   #11
mkoesel
Moderator
7512
Right, true, its just that if you want two devices plugged in, you are SOL. I Its too bad the tray does not preserve the outlet somehow (in some non-bstructive way), so you would still have it if you needed it in a pinch.
      10-20-2008, 12:42 PM   #12
J08M3
J08M3's Avatar
285
I believe there is a DIY on here somewhere with someone keeping the the cigarette lighter and doing the mod. But if I remember correctly they moved the location to outside on the passenger side of the console. I didn't like the look, plus the second source for power in unnecessary for me.
      10-20-2008, 01:02 PM   #13
McLuVan
McLuVan's Avatar
Vietnam
304
Drives: ///M3
todays "cool" sunglasses are huge
lmao
I have to put my frames in the glove and even then it barely fits
      10-20-2008, 03:39 PM   #14
Sticky
78
lmao
Yep, same problem.
      10-30-2008, 04:20 AM   #15
dar2008
dar2008's Avatar
303
Finally did this mod to my car, and extremely happy with how it went and the results!
Pictures are available here...
http://www.e90post.com/forums/showpo...&postcount=206
m3post
