01-29-2021, 03:04 AM | #1 |
199
Rep 196
Information for battery disconnection
I have an F83 and I would like to know if it is possible to disconnect the battery without having errors. I read that if you leave the car without the battery for a while, the control units reset, is that true?
How long can it be left detached, if it can be done? |
01-29-2021, 05:47 AM | #2 |
277
Rep 558
The only inconvenience with disconnecting the battery is having to tell the car to reset the time and if you use your trip odometer it get reset. Other than that, worry not
2017 F80 ZCP - Mineral Grey Metallic
01-29-2021, 06:48 AM | #3 |
199
Rep 196
Imperial328i277.00 |
01-29-2021, 10:32 AM | #4 | |
199
Rep 196
Sorry for the bad translation. |
01-29-2021, 03:53 PM | #7 |
184
Rep 364
Drives: M2C X5M M4
My advice for battery disconnect would be to open the boot first and let the car go to sleep then disconnect. This I follow as best practice as some control units are still awake and can get damaged.
I think the easy way to tell is by putting on the rear window lock and open the boot when the Illuminated button goes out it is safe to disconnect the battery. I think it's approx 15 minutes. I know loads of people just disconnect and it's fine but I've known of some pretty expensive control units getting damaged in past BMW's so I always am cautious |
gerri198.50 |
