01-08-2021, 10:48 AM | #1 |
Friends don't let friends ESS
3200
Rep 880
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
What's your daily driver warm-up routine?
It's reasonably well established that the S65 needs to be at operating temperature in order for the oil to provide adequate lubrication of the low clearance bearings at high loads. I've had BPM make a software change to lower my red-line to 4500 RPMs when cold and the red line increases linearly as the oil temperature comes up to goal, but I also eliminated the cold start routine. I'm 6 months into M3 ownership and still learning.
Mine is a daily driver, including short trips to the store, and has modest mods (stage 1 tune, test pipes, cold air intake, power pulley). For folks who daily drive their M3, how long do you sit there idling in the driveway on a morning cold start before taking off? To the end of the cold start routine? Until the oil temperature is visibly rising on the gauge? Until you shift it into gear? Currently I let it idle for about 30 seconds and start my drive, keeping RPMs low until the oil temperature is around 180F. |
01-08-2021, 11:00 AM | #3 |
3992
Rep 3,411
The lower cold start RPM redline is always a welcomed tune. At least for visual kicks!
I idle 30 seconds and go. Generally I keep rpm under 3-3.5k until oil hits 200. Which in the cold months with a larger oil cooler and radiator can take a long long time...
Not a Doctor, those are just my initials.
SAMM3Y3085.00 |
01-08-2021, 11:06 AM | #4 |
922
Rep 933
Drives: E90 M3
On average I'll let idle for 3 minutes or so. I'll start my car, walk back inside and grab my stuff and then head out. If im not at home I'll give it 30 seconds or when the cold start cycles through and my idle settles.
I always keep it under 3k and the throttle light until the oil temp needle starts moving. I'll typically give it 4-5k after the first hash mark, but still drive nicely until it hits temp. I actually drive it nicely 75% of the time, driving fast car slow type deal. I do make sure to get it up near redline at least once per drive. |
Davisca4552207.50 |
01-08-2021, 01:22 PM | #5 |
2208
Rep 865
Northern California, so the overnight low temperatures aren't super extreme (36f last night).
Always garaged and the garage is very well sealed and insulated. And if the pellet stove gets the house too warm, I'll open the door from the house into the garage, "to cool the house down" is what I tell my wife, but really, it's to keep the car warm. Typically I'll try to get into the car at least 5 minutes before I need to leave, open the garage door, fire up the car, wait for the initial high idle to drop and stabilize before I select reverse to back into the driveway and shut the garage door. I'll sit in the driveway for as long as time permits, but usually 5 minutes when the weather has been cold. When I start driving, I concentrate on minimizing the load that is being applied to the engine, and the rest of the drivetrain, as well as keeping the RPMs below 2500 if at all possible. Think, egg between the shoe and the throttle pedal. Real grandpa stuff. I won't get on it until I know the car is fully warmed up.
Chris, 2008 E92 |
Ajolives922.00 |
01-08-2021, 02:49 PM | #6 |
Lord Scrip
1820
Rep 3,015
Drives: 2011 M3 Coupe
I usually allow a 3 minute warm up minimally. Then I keep things under 3k RPM until temp reached. I have done this for 7 years and 224,000 miles without any issues. Done RB's twice over this time. Car is as jumpy as it can be still.
Powashiftin171.50 |
01-08-2021, 03:53 PM | #7 |
65
Rep 59
Cold start deleted with tune and car is garaged. But I start it let it run for 30-60 seconds before taking off and don’t go above 3500rpm until I get to the freeway. I’m about 10 minutes away from the freeway so it’s usually just under the 210 mark by the time I’m there then let her rip.
01-08-2021, 03:54 PM | #8 |
65
Rep 59
224k nice! Have both swaps been OEM bearings?
01-08-2021, 07:26 PM | #9 | |
Lord Scrip
1820
Rep 3,015
2nd all OEM @BMW dealer
01-08-2021, 07:37 PM | #10 |
3085
Rep 2,747
I try not to do idle warmups. I start let cold start die down as I'm backing out then go easy until I start seeing the temps come up and gradually build up revs.. my dad when I was young would always say "don't let condensation build up in the cylinders!" Which may or may not be true but it got drilled into me... he's from ye olde country though where winters are wet and cold.. most of summers too.
9ers
01-09-2021, 12:15 AM | #11 |
5865
Rep 6,637
Wait for cold start to finish then get moving. I try to keep revs 3k or under until I get an oil reading. Once I have an oil reading I'll raise rpm to 4K if needed. Generally car settles at 200 degrees on the highway unless it's hot out or I'm beating on it. It's been cold lately at 45 and the car settles at 190 on the highway.
01-09-2021, 02:36 AM | #12 | |
4480
Rep 7,120
On the warm up routine; I get going right after cold start and then keep well under 3k till warm. |
Davisca4552207.50 |
01-09-2021, 08:17 AM | #13 |
336
Rep 724
Start it up, slowly pull out of the garage, make a three point turn to be able to drive down my driveway. Keep revs low as I drive through a residential area. Takes about 5 minutes to get to the highway. Still take it easy on the revs until the oil temp has reached about 200.
01-09-2021, 08:58 AM | #14 | ||
408
Rep 583
* 2011 M3 DCT * Built 4.4L Stroker * Gintani supercharger * Brembo GT * BBS FI * OHLINS * Nardo Grey *
01-09-2021, 10:33 AM | #15 |
24
Rep 32
I usually wait for the cold start to finish (~30s) and then drive off, keeping revs below 3k and judiciously not using too much throttle (don't want to lug the engine) until temps come up to around 200, and then drive the car normally.
01-09-2021, 12:59 PM | #16 |
324
Rep 488
Drives: 2011 E90 M3 6MT
Start and wait for 30 seconds to 1 minute just to let things thermally stabilize and then 3k or under until warmish.
01-09-2021, 01:37 PM | #17 | |||
Lord Scrip
1820
Rep 3,015
acarr6407.50 Davisca4552207.50 |
01-09-2021, 04:08 PM | #18 |
2631
Rep 2,141
Drives: 2011 E92 M3
Start car. Drive. Don't bash on it until it has some heat.
Repeat.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
01-10-2021, 01:06 PM | #19 |
303
Rep 298
If the car is cold, I wait until the cold start cycle finishes and the idle settles, then keep the revs under 3k until the needle reaches close to 210. It usually only takes 7 or 8 minutes to get to 180-ish, and from there I'll go up to 4K if needed. 180-210 takes longer - sometimes 15-20 minutes if it's cold out. I never go full throttle or over 6k until full operating temp.
01-10-2021, 02:16 PM | #20 | |
223
Rep 979
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
01-10-2021, 02:17 PM | #21 |
223
Rep 979
Same expect it has to be fully warm before beating on it ...
01-10-2021, 02:25 PM | #22 |
897
Rep 940
I'll share my regiment. Seems like a few others do the same thing.
1) Start car, if cold start wait until RPMs drop to idle 2) Drive car under 3,000-3,500rpm until oil temp reaches 210 degrees 3) When oil temp reaches 210 degrees, I am free to rev above 3,000-3,500rpm. |
