12-23-2020, 12:26 AM | #1 |
Rep 17
Just changed Valve Cover gasket. Now SES light on with rough idle
Hello all,
So i have a 2013 Bmw128i that recently had the good ol VCG leak. I took it to my local mechanic and he just changed the VCG and spark plugs as of yesterday. As I turn on the car, I immediately notice the service engine soon light was on(which was never on before) and there is a pretty rough idle that jumps up to about 1000 RPM before dropping back down to about 500 RPM. My mechanic said he pulled the codes and it came back as a faulty mass air flow sensor. Now after looking up the symptoms it does appear to be in line with a faulty MAF but I NEVER had any issues with it prior to taking in my car for the VCG and spark plug change. The car seems to be driving fine, actually smoother than usual, until im idling. Then the engine kind of starts to bog down and feel like it may stall at any moment. Any ideas on what it could be? Is it strange these issues appeared right after my mechanic did the repairs? Its just frustrating to have one issue fixed while creating another. Any advice here would be appreciated, Thanks! |
12-23-2020, 09:25 AM | #2 |
785
Rep 1,000
Given what a PITA it is to replace the valve cover, I'm guessing he unplugged something and forgot to plug it back in.
Official BMWP Whore - BMWP suspension kit w/ M3 arms, BMWP big brake kit, BMWP intake w/Mishimoto tube, BMWP exhaust, BMWP carbon strut brace, BMWP short shifter, and BMWP carbon spoiler. OZ Leggera HLT w/ 245 square setup.
12-23-2020, 10:42 AM | #3 |
Just one more taste...
566
Rep 2,011
Eccentric shaft sensor? Is it manual or automatic?
My Build Thread: Jet Black 6MT 128i with MSport
12-23-2020, 11:08 AM | #4 |
785
Rep 1,000
Maybe a broken breather hose? I would think that could cause a lumpy idle.
They break if you breathe on them. It might literally combust if you said a cross word in its vicinity.
12-23-2020, 11:19 AM | #5 |
295
Rep 3,350
Your car is at the age where stuff like this will happen. You get one thing fixed, then something else pops up, shortly after.
I had the water pump replaced under extended warranty on my 135, and a few weeks later one of the small water hoses near the block started to leak. What can you do? It is probably the MAF - but rough idle can also be dirty VANOS or even a bad tank of gasoline. A month or so ago, I impulsively filled up with 1/2 tank of discount 91 Octane gasoline, the next day I started getting misfire codes on cyl 1 and 6. The car ran rough until it warmed up, similar to your rough idle. It ran fine after a few minutes, so I cleared the codes and kept an eye on things. After a few fill ups with Chevron Techron 94 Octane, it went back to normal again. No start up codes, and running smooth as silk.
2008 135i, Jet Black, 6 spd, Canadian Sport package, black leatherette, manual seats, aluminum glacier trim, PDC.
1983 E21 Delphin, M10, 5 speed, LSD, MSW wheels, recaro seats, Hartge strut brace, rear sway bar. [SIGPIC][/SIGPIC] |
12-23-2020, 12:20 PM | #6 |
828
Rep 2,232
I would have them triple check to make sure everything was re-plugged in correctly.
I recently had an issue where I took my car in to get some sounds diagnosed including rear suspension. The well known and usually recommended BMW specific shop to me forgot to plug back in one of the two connectors in each taillight and I had been driving around thinking the light error I had on my dash was for bad (non Can Bus or whatever it's called) interior LED lights I had installed a few weeks prior to visiting that shop. Finally pulled the codes after replacing my interior lights with better can bus lights and it was taillights. Opened the access panel in the carpet and finally noticed the outside connectors weren't plugged in. Always, re-check everything and make sure nothing is disconnected. Could also just need to clean the sensor. |
12-23-2020, 03:56 PM | #7 |
Rep 17
Thats kinda what it seems like. I dropped it back to him this morning and considering i havent heard a word since I'm thinking hes having a tough time figuring it out
12-23-2020, 04:00 PM | #8 | |||
Rep 17
Its an automatic
12-23-2020, 05:01 PM | #9 |
Rep 17
Now the mechanic is saying cylinder 1 and 3 are misfiring. He also changed the spark plugs yesterday as well.
Was not having any of these issues before he started the VCG repair. I feel like the car is in worse shape now than before i brought it to him smh |
12-29-2020, 02:23 AM | #10 | |
44
Rep 102
12-29-2020, 11:53 AM | #11 |
828
Rep 2,232
Curious what the spark plugs looked like? It possible oil either got on them and spoiled them, or maybe the ignition coils weren't plugged in correctly. It's so hard to diagnose these things without pictures, videos, etc. honestly. Just kinda shooting at random theories here.
12-29-2020, 12:14 PM | #12 |
4338
Rep 6,196
Really doubt it is the MAF sensor. Sounds like there is a vacuum leak, which would also explain the misfire in cylinders 1-3. First thing to do is a smoke test. Good chance there is a leak for the breather hose where it connects to the back of the valve cover. That hose would have had to be removed when removing the valve cover, and it will be very brittle.
The valve covers also tend to crack when being removed or installed. This is why we never replace just the gasket. Do you have the list of the exact faults? Probably air mass faults? |
12-29-2020, 05:30 PM | #13 |
785
Rep 1,000
Can confirm! I literally broke mine brushing against it.
MightyMouseTech4337.50 |
12-29-2020, 11:21 PM | #14 |
886
Rep 2,720
With all the great suggestions, ask your mechanic to check if he loosened and then tightened the ground connection or not.
Not sure If he needed to even touch it for this repair, but just in case. This is located on the right front wheel well area. |
