12-17-2020, 08:27 AM | #1 |
332
Rep 530
water getting into headlight
Lately I see water droplets inside my driver's side headlight. Not a lot of water, just a fine mist of droplets inside the outer 1/4 of the light - inside the face. I don't see any obvious crack or hole, and the entire face of the light is protected by Xpel wrap/film. I guess I will remove the headlight and look for obvious cracks, points of entry for h2O. If this has happened to you, let me know what you did or where you discovered the point of entry pls
12-17-2020, 09:21 AM | #2 |
295
Rep 3,350
If you have had the bulb cover off, it may not have been put back on properly. This allows water to get in.
There have been posts about this in the past. People have tried drying the entire light assembly in their ovens, and even placing packs of dessicant inside their lights to dry them out. |
12-17-2020, 11:33 AM | #3 |
131
Rep 185
Same thing happened to me recently. First the passenger side, then the drivers side about 6 months later.
My lenses were not protected, and being a 2009 they were pretty cloudy/chipped. Ended up buying 2 new OE headlight assemblies. All the bulb covers were properly seated. Halogens, if it matters. I used to own early-2000s VWs. On those headlights, it was common for the seal between the lens and the housing to fail. People would dry them out and run a bead of RTV around the lens to reseal. If my lenses weren't crappy, I would have tried this. |
01-15-2021, 08:56 AM | #4 |
332
Rep 530
I replaced the ballast and adaptive headlight module with aftermarket pieces from Amazon (China) after running a hair dryer into the headlight for a few hours to dry everything out. Ran a bead of silicone around the entire lens/housing interface because I really don't know exactly where the water was entering. The rear cover could have been loose, but I never removed it since purchase of the car. I can see how people don't get the cover tightly placed on the back of the light though. If you don't get the tabs into those 2 indents, it's possible to leave a gap right there at the bottom/rear of the light housing - right where the ballast sits.
