12-01-2020, 08:36 PM | #1 |
315
Rep 474
Drives: 2009 128i 6MT
AAA study on the effects of different fuel additive packages/fuel brands
https://www.aaa.com/AAA/common/AAR/f...ull-Report.pdf
Recently came across this (surprisingly scientific) study by AAA from 2016 that tests the effects of fuels that do and do not meet the TOP TIER fuel program standards. For the uninitiated, refineries are only required by law to meet EPA LAC (lowest additive concentration) requirements set way back in '96. The TOP TIER program is a LAC standard was created by manufactures (BMW included) for modern day engine tech. TL;DR: AAA test 6 different fuel brands, (3 that meet TOP TIER standards, and 3 that do not) by strapping a "Ford 2.3L port fuel injected engine" on a dyno and simulated highway driving for 100hrs/4000 miles with each fuel. (Not sure what planet this testing was done on, but it sure as hell wasn't earth if "highway driving" means 40mph.) Carbon deposits were then measured on the intake valves, piston top, and cylinder Results: Average deposit weights were as follows (from sec. 4.3, pg 15): Intake Valve Non-TOP TIER: 660.6mg TOP TIER: 34.1mg Piston Top Non-TOP TIER: 569.7mg TOP TIER: 526.3mg Cylinder Head Non-TOP TIER: 736.4mg TOP TIER: 893.8mg Total deposits for each fuel tested Non-TOP TIER 1: 2401.3mg Non-TOP TIER 2: 1856.7mg Non-TOP TIER 3: 1723.2mg TOP TIER 1: 1502.2mg TOP TIER 2: 1374.0mg TOP TIER 3: 1486.5mg Sample sizes of fuels used could've (read: should've) been larger, but the results for the intake valves are pretty black and white. Results for piston top and cylinder head deposits are up for discussion, as the data for skewed on both sides. It is also worth noting that switching to TOP-TIER brands can "reduce existing deposits that have accumulated over time over the course of a few thousand miles" (6.3, pg. 22) NGL, I'm guilty of filling up at the cheapest station in town regularly. I'm in the N52 camp, but having spent the last 6 months trying to solve a rough idle on cold start and a bit of a stutter when going WOT, I'm now convinced the extra few pennies per gallon are worth cleaning up the intake valves. I'm willing to bet that investing in TOP TIER fuels would cut back on how often the N54/N55 guys have to nut on their valves. Last edited by Papa Popov; 12-01-2020 at 09:39 PM.. |
12-01-2020, 08:41 PM | #2 | |
1542
Rep 3,071
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
Raularango19.00 |
12-01-2020, 09:15 PM | #3 |
315
Rep 474
I should've been running it all along, but I never thought that the difference was significant enough to pay for, especially when I was driving 350mi/week before WFH started. Turns out these companies' marketing departments aren't completely FOS after all
12-01-2020, 10:06 PM | #4 |
C2H5OH
3915
Rep 2,144
The head data is really confusing.
Was there and fuel consumption data tagged to each? Just a quick look i don't see any. Why is it the test mule is always a Ranger engine? LOL |
12-01-2020, 10:12 PM | #5 |
2183
Rep 2,806
I think cars with direct injection don't see the intake valve benefit. Your valves don't get doused with fuel like a port injection system.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
12-01-2020, 10:54 PM | #6 | ||
315
Rep 474
Only mention of fuel economy was the potential negative impact (2-4%) due to carbon deposits. Quote:
"...There are good reasons for doing it this way. Gasoline direct injection lets engine designers account for practically every molecule of gasoline going into the engine so they can extract the most energy and produce the least possible pollution. These are worthwhile achievements, but it also means that none of those molecules are touching the intake valves on their way to incineration in the combustion chamber. Intake valves have seals on them that keep oil lubricating where they meet the camshaft or rocker arms that press the valves open from running down their stem and dripping into the intake port. However, no matter how good they may be, a tiny bit of oil still makes its way past and runs onto those intake valve stems. Valvoline engineer Michael Warholic reports that Valvoline regularly inspects the insides of engines with a borescope, and what they are finding is disconcerting, “It's likely you'll see a small amount of oil running down the sides of the valve,” he said. Without gasoline washing them clean, that oil can bake onto the valve and accumulate into carbon buildup." https://team.valvoline.com/diy/truth...carbon-buildup |
12-02-2020, 12:01 AM | #7 | ||
315
Rep 474
gjm1202183.00 |
12-02-2020, 04:24 AM | #8 | |
1542
Rep 3,071
I know the fuel doesn't go over the valves to clean them in a direct injection motor but I find that the car runs noticeably smoother when I use Shell, Chevron, BP or other top tier gas. This was especially the case when I had my 545i & X5 4.4 v8 motors. With the turbo n55 it's not quite as noticeable but still there the motor just idles smoother and runs better.
12-02-2020, 12:06 PM | #9 |
2183
Rep 2,806
Using the attached and a little math you can probably make your own top tier fuel by mixing in a small dose of Techron with each fueling.
12-02-2020, 01:29 PM | #10 |
161
Rep 282
Results for non-top tier may not apply to California. Thought I read somewhere that all gas sold in CA had to meet the top tier spec by law even if it was not a top tier name brand. Part of their emissions regulations.
12-02-2020, 05:02 PM | #11 | |
43786
Rep 7,224
https://www.energy.ca.gov/sites/defa...e_Report_0.pdf Interesting, but not really conclusive. |
