11-18-2020, 02:44 PM | #1 |
Rep 5
Comfort Access question
My comfort access doesn't work. I have replaced the cars battery and the battery on the fob. The car starts with the fob in the slot .... I have had it lock the doors via the fob 2 times in the last 3 months but it will not unlock. I am pretty sure its the module in the trunk that is the problem. I have hit the button next to the antennae in the trunk and get no response. I am looking to find the location of the module in the trunk so i can source one. Can someone post a pic or give me an exact location for the module. 2009 E88 135i Vert. Please and thank you!
11-18-2020, 03:28 PM | #2 | |
545
Rep 1,233
I simply found a replacement on ebay and swapped it. It's located in my car (128i coupe) behind the trunk liner underneath where the storage cubby is on the passenger side. You need to remove the liner... |
11-19-2020, 05:09 PM | #4 | |
545
Rep 1,233
https://www.realoem.com/bmw/enUS/sho...diagId=61_1718 It's #1 in the diagram I assumed model year 2010 for you, but should be the same regardless. It's not hard to take off the trunk liner, worst case you spend an hour taking out the liner and putting it back, but you'll be able to see the module if it's there... |
Tags |
comfort access |
