11-18-2020, 07:53 AM | #1 |
479
Rep 1,065
Engine Machine Shops South Florida?
Hi bimmerpost F80 forum. I have an n20 but I figured this part of the board would know more info.
I'm looking for a machine shop to install sleeves + convert open deck to semi or closed + micropolish and balance crank/pistons/rods/bearings etc. I gave active Autowerk a call however they just told me to call Carbahn out in Cali for an engine build. I personally have modest goals (500-550 whp), and buying a n55/b58/s55 powered chassis sounds great, my current car is paid off. Thats the best kind of car to own IMO . Does anyone have an engine builder/shop they know here in Florida who is familiar with BMWs? I'm aware Mario's shop does external things but isn't a machine shop. Thanks |
11-18-2020, 08:18 AM | #2 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
I doubt seriously if you're going to find a machine shop that would be capable of converting an open-deck block to a closed-deck design - it would be easier to find a closed-deck block to begin with. That, and looking for 500+ hp from an N20 engine would likely result in seriously-reduced reliability. You'd be better off looking for an N55/B58 engine from a salvage yard that would produce more power without having to modify its internals.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
11-18-2020, 09:08 AM | #3 |
479
Rep 1,065
Cylinder support system does it in New Hampshire. Most machine shops can install sleeves and balance components.
https://cylindersupportsystem.com/ Was looking for someone locally/in the area more or less. Also the n55 is open deck too. B58 is the exception however 25k for a new car instead of have a built motor for maybe 1/5th of that makes sense to me. I do have a spare block, internals (Cp pistons + rods) in hand. Just looking for a good condition crank and order a new flywheel for the total balance and can send off to a shop...
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
11-19-2020, 07:45 AM | #4 |
1837
Rep 6,990
Yes, but the N55 can produce more power when tuned than an N20. You'd still be better off finding a used 6-cylinder engine, but to each his own.
11-29-2020, 08:31 PM | #6 |
1397
Rep 3,152
Try Miami Engines; they just did some custom things for a friends S55.
11-29-2020, 08:38 PM | #7 |
1973
Rep 2,711
They're not in Florida, but Billiam Mason or Ali Barakat may be able to help with your goals.
https://instagram.com/b_mase_monkey https://instagram.com/al1zilla |
