TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      10-09-2020, 04:58 PM   #1
titanle
titanle's Avatar
50
Drives: 2010 X6 Activehybrid
TPMS sensor
I want to add sensors to my aftermarket replica wheels. I found these ones online and just wanted to make sure it's the right one. Would I have to take it to Bmw or can any Indy bmw shop code them?
      10-09-2020, 08:05 PM   #2
denaliman
denaliman's Avatar
470
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Are you sure your vehicle has TPMS sensors? I ask because you are in Canada and if you have a Canadian spec vehicle as in your avatar you probably don’t have the sensors inside your tires. Canadian spec vehicles up to 2014 had FTM ( flat tire monitor) system not tpms. They work by measuring the tire’s rotation not pressure of the tire. I know this is the case with my 2013 X6M. If you are not sure you can confirm by just looking at the tire valve.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      10-09-2020, 10:09 PM   #3
titanle
titanle's Avatar
50
I have a 2010 X6 activehybrid US spec. The stock 19s had sensors and since I got aftermarket wheels I have the yellow light on the dash.
The wheels I have now are replicas. Is there a way to determine whether these wheels can accommodate sensors?
      10-09-2020, 10:34 PM   #4
denaliman
denaliman's Avatar
470
2013 X6M  [0.00]
They should fit your replicas no problem. To make sure you get the correct ones originally spec'd you can check on realoem by enterring your vin number and search. I don't think you need to go to the dealer to program. You will need to reset the TPMS in idrive then drive around for about 10 min. The electronics should communicate with the module to idrive and sync up,
      10-09-2020, 10:59 PM   #5
denaliman
denaliman's Avatar
470
2013 X6M  [0.00]
Take a look here, Hope this helps.
      10-09-2020, 11:44 PM   #6
titanle
titanle's Avatar
50
Thanks for the info. I was unsure about the programming because in the description of the sensor it indicates multi fit and that programming would be required.
I'll just have the tire shop install them on the wheels when they swap on the winter tires and then go for a long drive.
If they still don't register then I guess at that point I'd have to get a shop to program them I imagine.
      10-10-2020, 01:06 AM   #7
titanle
titanle's Avatar
50
I went on the ECS website and I found another set of sensors that are supposed to be the correct ones for an E72. I've sent them an email to verify fitment.
      10-10-2020, 07:36 AM   #8
denaliman
denaliman's Avatar
470
2013 X6M  [0.00]
Just make sure they are same ones currently on your car now to prevent any issue syncing up.
      10-10-2020, 09:12 AM   #9
titanle
titanle's Avatar
50
That's the thing. I don't have any tpms sensors currently. The oem wheels had the sensors and since then I've had three aftermarket sets of wheels. Online I've read that they need programming via the multi tool but it also says that they can be reset via iDrive. Perhaps calling a local shop will give me some info
      10-12-2020, 08:51 AM   #10
Mrathell
Drives: 2009 X6 35i / 2011 X6 50i
Geez, $239 for all four sensors
I ordered four new ones (non OEM) off of Ebay for $67 (total) a couple of years ago for my aftermarket winter rims and they work perfectly.
I didn't need to take it to the dealer, I just used the iDrive to get the system to recognize them.
      10-12-2020, 04:14 PM   #11
titanle
titanle's Avatar
50
Wow $67?!
Do you happen to have the link?
xbimmers
