10-03-2020, 04:50 PM | #1 |
Rep 26
TC super restrictive and invasive under normal driving
Hey guys! I tried searching for help before posting but I’m not seeing anything that solves my problem.
To sum up what is happening is that under normal driving conditions when I drive on the highway and there is either a banked curve or on changing overpasses I’ve lately noticed my Traction Control light coming on midway through the curve and cutting power. To say that I’m driving normal is an understatement. I commute on these highways and sometimes I’m behind a civic or old S10 truck when this happens. I have several mods Ohlin RT’s with swift springs Turner monoball bushings for control arm Turner sway bar links Sport alignment by local shop GTS diff, TC and MDM 20” wheels w Michelin P4S with less than 3k miles Any recommendations on where to start looking would be appreciated Louie |
10-03-2020, 06:45 PM | #2 |
1538
Rep 1,665
What size tires do you have? I have found even minor changes in tires sizes cause greater DSC intervention. I ran 255/35/19 and 285/35/19 for a while. It definitely caused traction control to intervene even going around a curve at slow/completely normal speeds and low G non aggressive driving conditions.
10-03-2020, 08:42 PM | #3 |
Rep 26
I’m running 295/25/20 and 265/30/20 in the front. I did come across a couple posts stating the same thing
I’m just worried that even though I’m not feeling any slipping that maybe something isn’t right and it is actually saving me |
10-03-2020, 09:42 PM | #4 |
858
Rep 1,561
Tire sizes. I had the same issue with 19's and I know exactly what your talking about. Long sweepers at 80mph my traction control is going nuts and cutting power meanwhile the minivan in front of me is hitting it no problem. For me I ended up with 265/35-19 and 285/35-19. Now I can even run without DSC on and the car feels 1000x better, stable and in my control.
10-03-2020, 09:45 PM | #5 | |
Rep 26
10-04-2020, 02:27 AM | #6 |
1538
Rep 1,665
265/30/20 and 285/30/20 will be back to stock 20" sizes so it should fix the problem completely. When I finally switched my fronts to 265/35/19 to pair with my rear 285/35/19 tires, all the traction control issues went away during normal driving. Obviously, it still lights up like a christmas tree when you peel out.
10-04-2020, 07:46 AM | #7 | |
145
Rep 468
2015 F80 M3 - Yas Blue, Silverstone Full., Bilstein B6 shocks, Eibach Springs, Full M Performance Carbon Add-ons, Titan 7 Wheels.
(past) 2012 E92 M3 - Melbourne Red - Eibach Springs/AG M359/ performance spoiler/ performance splitters/10mm spacers, Macht Schnell Test Pipes, Alpine Stage 2 Tune. |
10-04-2020, 08:41 AM | #8 |
21125
Rep 20,742
Drives: 2021 911 turbo
Your tire sizes certainly are not helping here. Since your rear diameters are smaller relative to the front compared to what the DSC expects, the DSC believes they are spinning faster than needed and hence cuts back on power. I have the same issue when running square track or winter tires. Some people say the DSC eventually adapts, but I do not believe it entirely does.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
10-04-2020, 09:49 AM | #9 | |
Rep 26
