09-18-2020, 10:56 AM | #1 |
103
Rep 129
55 flat screen TV fit?
Buying a new TV this weekend. Sure, I can roll coal in my crew cab long box but don't want to drive it unless I have to. Parking at Costco is already a PITA.
Anyway, my back seats fold flat. Can I haul the TV in the M car?
2011 M3 6MT
Alpine white, ZCP springs, AFE intake, Black ZCP wheels, Borla ATAK. BE bearings/ARP bolts 02MAR2020@ 60k. 2001 Ford F250 crew cab long box 4wd Diesel 6MT 1968 Impala Convertible, original owners |
09-18-2020, 11:11 AM | #2 | |
2149
Rep 3,651
I fit a new 42" TV in my E90 easily, I would think a 55" would certainly fit. |
09-18-2020, 12:19 PM | #5 |
103
Rep 129
Thanks. I took your advice and measured the shipping box dimensions. I have 2 inches to spare!
Samsung 55 Q7DT. I know nothing of TV's and don't really care to but my 12 year old Plasma finally bit the dust so have to replace it with something.
2011 M3 6MT
09-18-2020, 01:36 PM | #7 |
1938
Rep 1,903
Drives: E92 M3
Put box on the roof, tie it with a little bit of yarn, and hold it down with your arm as you drive. Safest way to get there.
Plan on removing it from the box to fit but it still might not fit well enough in an E92. I wouldn't tilt the TV to fit so most of the weight is on one edge. Just take the truck. |
09-18-2020, 01:49 PM | #8 |
262
Rep 333
Great thing about TVs these days is they are almost all excellent.
09-18-2020, 01:58 PM | #9 |
103
Rep 129
Seems to be the case. They all seem to be pretty good. When I said I don't care, I sort of lied. Refresh rate. I will spend extra to get a clean E90 M3 stuffing it into a corner!!!!
2011 M3 6MT
09-18-2020, 02:06 PM | #10 |
Lord Scrip
1820
Rep 3,015
Drives: 2011 M3 Coupe
I put a 55" in my E92 without any problems twice. Depending on the box you might have to take it out. My two 55" TV's fit in the car in their boxes though. Not both at the same time though.
09-18-2020, 08:30 PM | #11 |
480
Rep 485
Threw a 50" in the box in the back of my E92 with room to spare, a 55" should work. Just check the height of the box, that's the limitation.
09-19-2020, 07:38 AM | #15 |
433
Rep 855
Has nothing to do with type of screen. It's because the weight of the screen/panel driver could flex if the vehicle hits a large bump.
It's a warning for the stupid. Like the warning about drowning on the side of a bucket
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
09-19-2020, 07:59 AM | #16 | |
63932
Rep 24,824
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick60773.50 |
09-19-2020, 08:46 AM | #17 |
433
Rep 855
Again.. It's irrelevant to the type. All types CAN (not WILL) be damaged if the screen flexes. More likely with plasma, yes but, still unlikely if you're careful.
I recommend keeping your EDC in comfort mode just in case.
///M Power-Belgium63931.50 |
09-19-2020, 08:48 PM | #19 |
497
Rep 458
Anything up to 70" will fit, I did the measurements when I bought one.
The minimum trunk width is about 36" and a 70 inch w/o bezel is around 35". I've moved TVs on 6-7 different occasions with this car. |
