09-12-2020, 04:00 AM | #1 |
320
Rep 474
Drives: 2009 128i 6MT
Oil Pan Drain Plug Bolt Repair
So I found out that my (otherwise clean) 128i that I picked up last December had the oil drain plug overtorqued, which I found out when I went to do my first oil change in May. I had to pay a shop to remove it, and they put in an oversized bolt, which has been good sans the occasional drop or two of oil. However, my car is coming up on 110k miles, and there's a slight leak from the OPG, so I'm considering having that done as it is too much for me to do in my apartment parking lot. I'm currently weighing my options, which are as follows:
-Deal with a slight leak from the plug. Oil level sensor hasn't dropped at all in the 3 months since the bolt was replaced. -Have a timesert installed. All of the shops I've talked to have never heard of this, and only mention helicoil. From my research, threadsert is superior - Have the entire oil pan replaced. This one is gonna hurt, as the pan alone is $650 at Turner. However, this seems like the best approach with the most peace of mind. Any input is welcome. I'm hoping to get the car in ship-shape over the next month so that I don't have to worry about anything for a while. |
09-12-2020, 12:22 PM | #2 | |
1224
Rep 1,221
https://www.stahlbus-us.com/stahlbus...r4d4ure5pmc9st I haven't had any problems with leaking from the plug. If you are worried about leaking though, you can put some thread sealant on there, like Hylomar Blue. FWIW, I just screwed the Stahlbus directly into the new threads on the aluminum pan... no inserts or anything. If you are going to go with a removable plug, an insert would probably be a good idea though, because the aluminum threads are probably going to get messed up again at some point. https://smile.amazon.com/Valco-Cinci...9931329&sr=8-1 There are other options besides the Stahlbus too (although I like it's design the best). http://www.fumotousa.com/parts.php?p...&partnumber=36 https://yhst-137220973255828.stores....f5ecwitec.html |
09-12-2020, 12:39 PM | #3 |
851
Rep 2,281
Yes the oil pan gasket most likely will need to be replaced BUT I highly recommend joining BMWCCA and SC chapter in Greenville. The people there will tell you the best BMW garages with the best prices.
