09-02-2020, 12:45 AM | #1 |
Rep 13
Oil level sensor concern
So i bought my 2010 x5m a little over 2 months ago. 129k miles. I put 1k miles on it when i first got it and in that time it burned/leaked about 3/4ths a quart of oil according to the oil level meter. Got the oil changed, dealer used 10w-60. I have put about another 1k miles and my oil level meter hasnt moved. Im a little concerned it might not be reading correctly.. Is my only option to drain the oil and see if theres still 9 quarts? Or is it not something to worry about?
09-02-2020, 03:20 AM | #2 |
i'm just saying
5739
Rep 2,634
sometimes oil level meter doesnt work that sensitive or dumb i should say, it might go down fast in one drive.. you can manually let the car calculate the oil level again while driving not in stop go traffic but in a steady ride or idling on a flat surface.. best result will be under operating temp of the oil so you can let the car recalculate then..
and there were some talks like a myth that there is a dipstick on E70-71 S63 engines but since i sold the car never tried to find it.. you can start by taking the cover off.. on 35d video shows dipstick.. S63 probably has it in a different area and actually newer V8's has it and its not hidden dipstick thankfully clearly there is one..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
09-02-2020, 09:30 AM | #3 |
37
Rep 119
Definitely no dipstick on the S63. If you're concerned about the oil level sensor replace it as its not that hard - 3 bolts and a electrical connector and you're done. Gonna have to change the oil while you're at it tho.
Here's the part from FCP Euro: https://www.fcpeuro.com/products/bmw...607910#fitment Here's the diagram: http://bmwfans.info/parts-catalog/E7...ator#7607910_7 |
09-02-2020, 06:09 PM | #4 |
66
Rep 247
Looks like one would need to remove the cross brace to gain access, right?
I’m questioning the accuracy of mine. 120k on the odo
'01 740i Sport; ‘06 Z4M Original owner, no mods
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31 |
09-03-2020, 01:13 PM | #6 | |
2022 M4 Comp Xdrive
1015
Rep 1,538
S63 absolutely has no oil dip stick. |
09-03-2020, 10:32 PM | #9 |
66
Rep 247
Plenty of places assume “M motor = 10W60.”
As previously mentioned, that isn’t correct. Others can speculate to the size of the problem, but I wouldn’t run it in my X5M. However, it’s the only oil I use in the S54 engine on the Z4M.
09-03-2020, 10:41 PM | #11 |
2022 M4 Comp Xdrive
1015
Rep 1,538
09-03-2020, 11:28 PM | #12 |
1359
Rep 755
Drives: 2019 BMW X6M
YUP. It is even wrong for the engine it was made for, the S85 V10, at least in the opinion of this engineer who wrote an lengthy article regarding engine oil, mentioning the bearing issues on those engines, so not first hand experience. Definitely wrong for the S63 IMO.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
09-04-2020, 10:28 AM | #13 |
Rep 13
Well looks like i will be doing another oil change, i think i will change the oil level sensor out as well just to air on the side of caution. so 5w-40, i can get royal purple for next to nothing through my work. definitely wont take my car back to that dealership for any reason. i was planning on going camping, about 250 miles round trip this weekend, should i change it out before then?
09-04-2020, 11:38 AM | #14 |
Rep 13
strike all that, i feel pretty stupid. just went back and looked and they did use 5w30. I feel a little dumb now. for some reason i remember the service writer mentioning 10-60. regardless, sounds like i need to replace the oil level sensor so ill be doing that soon.
09-04-2020, 05:25 PM | #15 | |
2022 M4 Comp Xdrive
1015
Rep 1,538
Nice. The sensor is very easy to replace. |
09-04-2020, 07:51 PM | #16 | |
1359
Rep 755
2019 BMW X6M
09-04-2020, 11:21 PM | #17 |
403
Rep 1,171
I wouldn't change the oil sensor. Seems like a waste of money to me. There will be other things that you will need for real repairs in the future.
09-05-2020, 02:32 AM | #18 |
Rep 33
if you persist with 10-60 you will start to hear the tappets as the oil is too thick and will cause expensive problem i made that mistake ,if you are losing too much oil with 5-30 its probably time to change the valve seals.
09-11-2020, 09:44 PM | #19 |
288
Rep 593
It has been my experience ever since my 5.0 started burning oil - after initial oil change at the dealership it takes twice as long as usual for the oil meter to move. After it drops down to minimum and requires a quart to top off, it usually takes half the miles for it to drop back to minimum.
I can see two reasons for it - first maybe the dealer is overfilling, especially if they are not using quart bottles but pump it out of a high capacity tank. Second, if you check history, back around 2013 or so BMW actually revised their recommendation for oil capacity for N63 and S63 engines from 8 quarts to 9 quarts. This is when the first batch of oil consumption issues started to surface, and so BMW used a cheap trick to keep complaints to a minimum. Thus, after an oil change you essentially have an extra quart of oil, but your computer oil meter is set for the original quantity of oil, and so it only starts to drop when a whole quart has already been consumed by then engine. Here is a decent video regarding this. |
11-03-2020, 12:46 PM | #20 | |
Rep 75
