      09-01-2020, 02:36 PM   #1
Nateboosted800
Drives: Bmw 135i
P0174, random stumbling idle,
2010 135i, 130k, vsrf charge pipe, completely stock other than that. Car runs and drives just fine other than the Random stumble when cold.
After so many miles this p0174 will come back on after i delete it
I cleaned the map sensors no change
No hissing noise
No visible vacuum leaks
Possible injector issue theyre still index 7?
Could it be a o2 sensor since its just one bank thats lean?
      09-03-2020, 09:05 AM   #2
Petro135
453
Drives: 2008 135i E88
2008 BMW 135i  [0.00]
Unfortunately it could be alot of things. Before you go replacing parts you should have an indy mech find
the issue. Could be o2 sensor, could be vacuum leak, could be fuel pump, could be injectors. Or even more. Or something real simple.
Do a log and see how your ltft's are. Then do a little research and see if they are in normal range.
      09-03-2020, 06:08 PM   #3
Tuxedo
Bowties r cool ▶:◀
Tuxedo's Avatar
1409
Drives: 09' 128i MT e88, 24'G05 X5 50e
No hissing noise
I've had 2 128i N51 with this issue. Short answer is it's a software issue of some kind
SIB12-15-14 there might be a newer update
Aging coils and plugs can enhance the issue.
https://www.scribd.com/document/1519...T-Stalling-TSB
      09-08-2020, 12:10 PM   #4
Nateboosted800
Drives: Bmw 135i
Theyre all in the normal range
      09-08-2020, 12:21 PM   #5
nazali
nazali's Avatar
1312
Drives: 230 2020 vert F23
is that with an OBDii or ista ?
any BMW codes
running lean ? hmmm, I've found that cleaning the MAF doesn't always do it, I'd change that out, pull the plugs and check them
if more than 50k on thoes plugs change them, use OEM's
      09-08-2020, 12:26 PM   #6
Nateboosted800
Drives: Bmw 135i
any BMW codes
P0174 code
I data logged with the jb4 and the lp and hp fall within the range
      09-08-2020, 10:40 PM   #7
nazali
nazali's Avatar
1312
I use ista, reingold,inpa, BMW software, never lets me down and gives me all I need. When I get similar issues I rely on that and it usually pulls me out of the soup. I don't know enough about JB4what it can and can't do diagnostics wise.
just IMHO, without more info from Ista or other codes, that maybe only ista will see, I don't know, hence why I asked
P0174 code
1addicts
