TireRack
      08-28-2020, 03:52 AM   #1
kcet
Drives: bmw 3.20ied 40.year edition
Widest rear tires possible ?
Good day everyone ,
Yesterday I saw one x5 with rear tires wider than normal and it looks so good and aggressive. Probably most of x5's in my country are comes with 315 width rear tires and it was bigger certainly bigger than that but I dont know the exact width.
Please share your x5's photos from back or just inform me what would be the max width with 20 inch rims.
      08-28-2020, 08:54 AM   #2
X5 MAN
78
Drives: 2011X5 50iM-Sport;2016X3 35i M
Originally Posted by kcet View Post
Good day everyone ,
Most X5 come with 255 or 275 width as standard.
Only M sport package and M have 315 width in the rear.
Any wider then 315 and you will have to lift the suspension and put new wheels
You must have seen 315 and thought they are wider.
      08-29-2020, 01:20 PM   #3
Texmexm5
Drives: 2011 X5M
PZero
im running 295/30/22 front, 335/25/22 Rear, no issues
m5james431.00
      08-30-2020, 06:35 AM   #4
kcet
I know that m sport versions come with 315 rear width. But I would like to know how it's looking when you upgrade it to 325 or 335 and possibility to stay with same 20 inch rims.
      08-30-2020, 06:40 AM   #5
X5 MAN
78
Are you a monster truck fan ?
      08-30-2020, 10:10 AM   #6
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Problem with running big rears (from what I learned recently) is mostly the issue with how big you can run the fronts with out rubbing on components. 295 seems to be the biggest.
335 for rear is pretty over kill but wow a 25 profile for the rear?
      08-30-2020, 01:59 PM   #7
Texmexm5
Drives: 2011 X5M
haha yeaa just lower to the ground
      08-30-2020, 02:00 PM   #8
Texmexm5
Drives: 2011 X5M
i wanted the biggest ones i could fit. so those are them lol. but i mean ive been driving on that size for almost 2-3 years, no issues. cant rotate just side to side.
      08-30-2020, 02:05 PM   #9
Texmexm5
Drives: 2011 X5M
i mean i am from Texas also. like to go big i guess lol
      09-03-2020, 04:18 PM   #10
m5james
m5james's Avatar
431
Drives: '10 X5M Alpine White on Sakhir
I'm running the same...I can still break them loose when the trans is flashed to RWD only.
Not me but you get the idea -
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      09-13-2020, 09:08 PM   #11
tlewis950610
2011 x5d: 2013 x5d
Drives: 2011x5d: 2018x5d: 2013x5d sold
2011 x5d  [0.00]
2013 BMX x5d  [0.00]
I have a 2011 and a 2013 x5d and I'm considering 285-40-20 front and 325-35-20 rear for my 2011. The height of this set up comes to 29 inches which is the same as the stock 255-50-19 that came from the factory. I'm not sure if the width will be a problem or will the tire look to fat. I'm doing it for the look because I don't drive very aggresive except when passing. If anyone has any suggestions or cautions please reply.
      09-14-2020, 07:21 AM   #12
X5 MAN
78
im running 295/30/22 front, 335/25/22 Rear, no issues<<<
He has no issues with those overfat tires, then you should not either.
      09-22-2020, 03:53 AM   #13
kcet
Can someone post some pictures from rear to see that aggressive look of 325 or 335's.
      09-22-2020, 07:44 AM   #14
X5 MAN
78
It will look like a farm tractor from the back
      09-22-2020, 08:33 AM   #15
mitch808
107
Drives: 2012 X5 35i
It's just 10mm wider than stock, or 20mm wider than the stock 315...
I'm not sure, visually, if someone can tell a 10mm difference from the back when looking at any X5 on the street.... Add to that, many manufacturers, while they state a value of X for a width, you'll find that it can vary some based on the thread design and sidewalls.
Changing to a more aggressive tire block tread could have a bigger impact visually than going from say 315 to 325.
2012 X5 xDrive35i Sport Activity - Alpine White - M Sport Package
      09-23-2020, 04:56 PM   #16
tlewis950610
2011 x5d: 2013 x5d
2011 x5d  [0.00]
2013 BMX x5d  [0.00]
An quick online view of a set 335s can be seen by typing in Rennen x5. This is a presentation of a highly modified x5 in 2014 at SEMA. Its not the best but gives you and idea.
      09-23-2020, 06:41 PM   #17
X5 MAN
78
Yes, the width is 20mm more with 335 . but the diameter is less and RPM are 17 more then OEM
      09-24-2020, 09:21 AM   #18
TSFFARMER
Drives: bmw x5 x35d diesel
Good day everyone ,
following. wondering the same on a 2010 X5 x34d
xbimmers
