08-26-2020, 12:31 PM | #1 |
311
Rep 469
Zombe1 135i Restoration/Build Thread
Long story and I'll try to keep it short and sweet, I am bringing a beautiful AW / Red spec 135i back to life after a horrible history with repossession and what appears to be a cover up from a track accident...
At the beginning of Covid (BC) I was looking for a replacement vehicle for my wifes Ford Focus Titanium 12' she bought 6 years ago. I managed to short sale it a bit for 4500. Giving a budget of only 4500 and what I was willing to put in for an upgrade at the time. Keeping in mind she wanted an X1 first gen or 1 series first gen I set about looking at vehicles. I'm no stranger to flipping and buying cash cars. That being said I have never bought a car without first taking a look at it in person. This is the first and possibly last time I will do this Based on the requirements that she refused to drive a manual, my only real option IMO was a DCT car which was made for the 11'-13' years. Didn't want to consider a smaller motor or 4 cylinder turbo without a manual. Already got stuck with the 4 cylinder tragic ford for 6 years so this time I would have to make the gamble. Found this car well below any 135i or X1 35i listed anywhere for N55. Sitting on a lot in Texas with a clean title and 4 owners. First sign of how bad I expected it to be was the headlights being miss matched, the terrible plati-dip all over the car probably hiding terrible paint or unpainted parts. The good news is that it had the exact interior exterior color combo, transmission the wife wanted. It also had a DINAN Exhaust indicating someone did modify the car at some point. OK so $7000 plus shipping later the car arrived HOW BAD WAS IT? The list is long and I probably wont remember everything but I'll try Repairs and Maintenance needed: Cooling System Overhaul | Valve Cover Gasket | Oil Pan Gasket | Oil filter housing gasket | Oil filters | Oil | Wheel lugs | Tires | Front radiator | Front Radiator Fan | Front Core Support | Oil Cooler Brackets | Bumper Support | Hoses | Plugs and Wire harnesses needing repair or replacing | Underbody panel cover | Front right fender liner | Headlight Bracket | Headlights broken tabs front and left | Right headlight Ballast | Right headlight adaptive sensor | OBD cover | Spark Plugs | Ignition Coils | Confort access module | TPMS Bumper sensor | Confort Access bumper sensor | O2 sensor For the body: Front bumper stained with plasti dip Right front fender stained Side skirts damaged Front left fender is wrong color Hood appears unpainted or black and stained Roof cannot get the plastidip all the way off 2 Gallons of dip dissolver and 3000 psi pressure washer 10 hours of spraying and removing plastidip New front fenders, new 1M style front bumper, new OEM style sideskirts Used 18" e92 313 (with tires I will be replacing) Alpine white Paint, paint clarifier, sanding paper Bought a whole front end from a salvaged car Tried buying a used right front headlight and using it for parts and repair, unfortunately I will be buying a set of front headlights as this is an issue Currently the bodywork is being painted by a friend (fingers crossed it comes out well). The repairs listed above have all been made except the front bumper sensors and the headlight brackets on back order. She is mechanically 100% but looks completely like a Frankenstein (we nicknamed her Zombe1 on the license plate) See current pictures below I will be posting updates and pictures as the body parts come in and the car gets possibly repainted or paint matched. Currently the roof is an issue, finding headlights is expensive, wife wants a cf hood, Comfort access still isn't fixed and has thrown me for a loop she still needs new tires and an alignment. Body parts came back from the painter friend. Battery was having phantom draining issues. Completely dead and had to be towed to my mechanic. After inspection the coolant leak was an o ring, headlight brackets should arrive tomorrow. Waiting to see how she looks with everything put on except the hood. Stay tuned
Current: 13' C2S 911 / 11' 135i / 05' Xrunner/ 10' X5D (Youtube: Peepshit Studios) Past: 1991 325ix Coupe Turbo / AP2 05' S2K / 981 Boxster/ 2007 Z4MC/ S13 240SX/ 2002 S2000/ 2004 350Z/ E39 1999 528i/ E46 2004 SC 325CI/ E30 1989 325i Vert/ 1987 E24 635CSI/ 2012 135I Last edited by DJKapeesh; 08-21-2021 at 10:28 AM.. |
08-26-2020, 02:51 PM | #2 |
545
Rep 1,233
Good luck with this build...
On the comfort access - the module which is below the rear passenger side cubby in the trunk gets wet (bad taillight seal or whatever). Hopefully it's just that. |
08-26-2020, 04:19 PM | #3 |
43783
Rep 7,224
This video looks painful.
https://www.1addicts.com/forums/show....php?t=1739953 Good luck with the car! PS - I like the 313s. |
07-15-2021, 11:12 PM | #6 |
311
Rep 469
Updates
Car has now had the valve cover replaced by me because of the boost leak squeal coming from top of the cover. Reprogrammed the car because the TPMS was not recognizing the sensors inside the 313 wheels to turn them off. Headlight adapter sensors turned off. Looks like backup sensors do work after replacing the module. Comfort access features do not work and the automatic headlights and automatic windshield wiper sensors don't work either. Battery issue was a fuse problem on the battery bracket. New tires, to go along with the 11k in maintenance and repairs I've completed so far. Basically all gaskets, hoses, cooling, oil parts, front bumper brackets and clamps etc have been replaced. Unfortunately the alpine white that was used to paint the front parts were a different alpine white and don't match. Picked up the car and dropped it at a paint shop last weekend to have it sanded down for the remainder of the Plasti dip and replayed one color. After taking the car to the mountains for a shake down last weekend I also discovered the front control arms are shot and the tires rub badly under hard turns. Going to replace the front control arms after it gets back from the paint shop and give her another shake down
Current: 13' C2S 911 / 11' 135i / 05' Xrunner/ 10' X5D (Youtube: Peepshit Studios) Past: 1991 325ix Coupe Turbo / AP2 05' S2K / 981 Boxster/ 2007 Z4MC/ S13 240SX/ 2002 S2000/ 2004 350Z/ E39 1999 528i/ E46 2004 SC 325CI/ E30 1989 325i Vert/ 1987 E24 635CSI/ 2012 135I |
07-16-2021, 11:07 AM | #7 |
828
Rep 2,232
The automatic headlights and wipers thing, I wonder if it's related to the sensors in the rear view mirror?
Also, if those are e92 313s instead of offsets for the 135is, then there may be some fitment issues beyond just the control arms being shot. I don't remember the exact difference though. |
07-19-2021, 10:50 PM | #8 | |
311
Rep 469
The search continues
07-22-2021, 12:50 PM | #9 |
OG Tray Deee
82
Rep 261
Nice! Looks like a fun project minus the headaches of course
sliebhard10.50 fossduncan0.00 |
08-21-2021, 10:30 AM | #10 |
311
Rep 469
Added a video to the main post
Body shop has had it for over a month struggling with the Plasti dip Chose to go with BMW individual Brilliant White Metallic Will update some pictures when complete
Petro135452.50 |
04-19-2022, 08:41 PM | #11 |
311
Rep 469
Update
After 6 months at the mechanic for an FRM replacement out of recall and the working with BMW to get the car to recognize the key I got the car back. Took advantage of the down time and put a few upgrades and get some maintenance done. Suspension was blown and the 313 wheels were scraping in corners and bumps so the list goes: Bilstein PSS 14 coilovers VRSF 7.5 front mount intercooler Seibon M3 style CF hood Dinan Camber plates MHD tune Unfortunately still not painted and was just now able to get to the paint after having it stuck in the trunk for half a year. Having some serious trouble finding a place locally who can do the job where the other body shop left it incomplete. Drives like a dream now, just wish it looked the part Currently this is a 24k+ project car believe it or not and still unpainted
tracer bullet2414.50 |
04-19-2022, 10:22 PM | #12 |
270
Rep 367
This is the reality of getting a project car instead of a well maintained car to begin with. In the end you don't save anything and in your case it looks like you've spent more. Hopefully you've enjoyed working on it. That has some value.
04-21-2022, 02:35 PM | #15 |
546
Rep 518
I'm digging the progress on the build, that plastidip was so, so bad. Can't wait to see the nearly finished result of your progress. Keep it up man!
Mods to date: The list grows...
05-11-2022, 09:37 AM | #17 | |
1051
Rep 782
Drives: 2010 328ix E91, 2011 128i E82
K9Leader 2010 328i x-Drive, E91 - Space Gray/Black 2011 128i E82 6MT - Crimson Red/Black |
05-16-2022, 12:42 PM | #18 | |
180
Rep 308
05-17-2022, 11:12 AM | #19 | |
311
Rep 469
I was on the way back from an SCCA Autocross event with the car Unfortunately my Valvetronic Actuator and motor most likely died so I was doing a bit of a limp home I literally just did some maintenance before the event - ABS Wheel speed sensor -Radiator coolant hose and attached lower hose This is truly the car that keeps on giving
09-07-2022, 04:19 PM | #20 |
311
Rep 469
Update:
Some shots the body shop sent me of the car from last week Looks like it's almost ready for pickup. Will have the details and full photos for you later
Tags |
build, build thread, rat rod, restoration |
