08-11-2020, 08:31 AM | #1 |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
Car stumbles a little during brisk acceleration
For the past couple of weeks, I've noticed that when I accelerate briskly (not hard) the car stumbles a little like it's got a misfire or something isn't engaging mechanically.
If I rev the car rather hard when parked I don't notice any misfiring in a coil or spark plug and if I'm accelerating gently, I don't feel any stumbling at all. Drivetrain problem? Differential? Any ideas?
08-11-2020, 03:16 PM | #3 |
Someone Else
62
Rep 79
I get this as well but generally only in 6th (6mt) when overtaking. I usually have to drop to 5th for it not to do this.
"Seats and a steerin' wheel" - N54 E82 135i | AR DP's | OSK DCI | VRSF CP | TS BOV | M̶H̶D̶ ̶S̶2̶ Stage 1| 2̶6̶0̶R̶W̶K̶W̶ (less)| 6MT | MPSS
08-11-2020, 05:20 PM | #4 | |
998
Rep 3,784
Seems to typically stumble when I go from 2nd to 3rd gears. It's just momentary, as if a plug misfires. Um, How do I create a log?
08-11-2020, 05:38 PM | #5 |
130
Rep 82
Most of us go through MHD or jb4 , you can use a more advanced scanner like an nt510 too to record data but without any of these your pretty shit out of luck to figure it out this way. Also pretty invaluable to have to read stored and pending codes that may relate to your issue. Pull your plugs and look for anything abnormal, there's a laundry list of things that can cause this. failing fuel pump, clogged or leaking injectors, failing coils, fouled plugs the list goes on and on
08-11-2020, 07:30 PM | #6 |
1Addict
3233
Rep 7,894
Not sure how to log on the N52.
What's the mileage on the following? Plugs Coils O2 sensors Fuel pump Other than that, is it a hesitation or a surge? And what happens with the revs if you push it through? Do they spin up freely with no speed increase or hang? Any exhaust detonation during these events? Any shadow codes?
08-11-2020, 10:48 PM | #7 | ||||
998
Rep 3,784
I did remember that I had an app (https://play.google.com/store/apps/d...rscanner&hl=en) with an ODBII bluetooth dongle... I ran the app and it reported no Diagnostic Trouble Codes. I guess I'll have to take it to my mechanic and have him look at it.
08-12-2020, 08:46 AM | #8 | |
1Addict
3233
Rep 7,894
Afam28298.00 |
08-13-2020, 02:02 PM | #9 | |
998
Rep 3,784
Now that I think about it, I don't sense/feel that hesitation when I'm not moving and revving the engine, only when I'm in motion... Seems like the drivetrain, maybe the differential? I remember the diff on my E36 failed and I had it replaced. I don't remember the mileage on it.
08-15-2020, 04:11 PM | #10 |
998
Rep 3,784
I pulled each of the plugs and checked them out. What a pain in the ass it was, having to remove all of that extraneous crap to get to them. Not to mention that brace from the shock tower getting in the way. Now I've gotta lie down and rest my back.
All of the plugs pretty much look like this one, which I think is OK:
08-16-2020, 10:43 PM | #12 | |
998
Rep 3,784
If the gap is too big and/or there's a bad coil, wouldn't I have gotten an error code?
08-17-2020, 12:04 AM | #13 | |
270
Rep 367
08-17-2020, 07:53 AM | #14 |
998
Rep 3,784
0.022"?? When I Googled for that info, I got 0.043"
I've been checking almost every day... No codes at all.
08-17-2020, 01:09 PM | #15 | |
270
Rep 367
08-17-2020, 02:56 PM | #16 | |
998
Rep 3,784
Can't seem to find a consensus on the plug gap for an N52 engine: 0.020", 0.022", 0.040", 0.043"...
08-17-2020, 06:17 PM | #17 | ||
815
Rep 1,199
The spec for the N51/52 NGK LZFR6AP11GS is 0.043". That is only measurable when they're brand spankin' new. Those plugs look fine and if <75K miles, they're definitely still ok. It's a waste of time to check on them unless you're experiencing issues. And if you are, then you'd best just buy 6 new ones because getting the old ones out just to put them back in is silly for the effort. Your problem sounds like my E46 felt when I had a bad coil. It wouldn't set a misfire code unless I drove the shit out of it. On the street I thought the transmission was slipping. It was just a coil. I'd probably just get a whole new set of coils and spark plugs and end the issue once and for all. If you're hesitant to do that, then drive the car really hard until it sets a code.
bmw1racer998.00 |
08-18-2020, 10:45 AM | #18 |
Needs a long road trip...
348
Rep 527
If I was a betting man, I'd say coils. I had the same thing happen to the 128 I was buying a few years ago. This random stumble won't throw a code. Go with the delphi coils, the bosch are being dropped by BMW. Change all 6. These are known to start failing around 30k and act just like you're describing, random stumble under modest acceleration...
bmw1racer998.00 |
08-18-2020, 02:10 PM | #19 | |
998
Rep 3,784
Delphi coils and NGK plugs from FCP Euro... $215.
olds350348.00 |
08-23-2020, 10:45 AM | #20 |
998
Rep 3,784
My coils and plugs haven't been delivered yet, but when I drove the car today, it stumbled a lot and I got a Check Engine light. It went away after driving a little more. I ran the ODBII scanner as soon as I got home.
The ODBII report: ============1============== 29CD Raw code: 29CD ECU: Engine control unit Status: Pending fault present, Validated fault has been present during this drive cycle Engine Control Unit?? Uh oh. Is it possible that it isn't the coils/plugs at all? Or is this fault code a result of failing coils/plugs?
08-23-2020, 04:33 PM | #21 | |
815
Rep 1,199
I would swap the coil from cylinder 1 with another coil and see if it follows. I'm pretty sure cylinder 1 is the farthest forward but you can swap 1 and 6 and you'll know you've swapped it. If you get a new code for cylinder 6 then you definitely know coils are the issue. On the other hand you've already bought the coils so may not be worth the effort.
bmw1racer998.00 |
08-23-2020, 06:23 PM | #22 | |
998
Rep 3,784
Thanks for the support... It's really appreciated.
