TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      08-03-2020, 11:01 PM   #1
1er_vert
72
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
New AGM battery draining, after FRM replacement and registration WTH?
What is the usual culprits?
Heat? (It was 114F today)
Alternator?
Voltage regulator?
Intelligent Battery System?
USB charger?
I'm stumped...
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      08-06-2020, 10:24 AM   #2
Colodano
131
Drives: 2010 X5M
How much are you driving? These rigs pull a bunch of power for little stuff, and take a bit to charge, if you aren't doing at least a couple of longer drives a week, it isn't going to hold up.
      08-10-2020, 11:13 PM   #3
1er_vert
72
Fully charged, new AGM battery drops to 11.7v after cold start. It just slowly keeps dropping after a few miles, even with no accessories or running lights. I bet if I disconnect the negative lead the engine would quickly die. Ugh. Sounds like a new Alternator is needed.
      08-11-2020, 05:36 PM   #4
Colodano
131
Drives: 2010 X5M
Yep, I think you have it nailed there.
      08-17-2020, 10:41 PM   #5
1er_vert
72
Alternator, Alright...
All good, now. Voltage is holding from 13.5-14.0 on AGM 95aH 950CCA battery.
      09-02-2020, 11:01 PM   #6
m5james
m5james's Avatar
431
Drives: '10 X5M Alpine White on Sakhir
Battery coded after the swap? I was having voltage spike issues that would cause modules to freak out...TCS, ABS, parking, etc. Valeo lternators are like $900, new brushes are $7 on eBay so I replaced them myself.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
xbimmers
