TireRack
      08-02-2020, 06:18 PM   #1
tmvatlanta
65
Drives: E39 M5, E70 X5M, 90 Z32TT, 360
2010 BMW X5M  [0.00]
Why can't I reset the brake pad warning?
Using the cluster and it doesn't change/reset. I watched and followed a couple of Youtube videos.
Car is a 2010 X5M.
2000 E39 Dinan M5
2010 E70 X5M
1990 Straman Z32TT
2001 Ferrari 360 Spider
1996 Mitsubishi 3000GT Spyder
      08-03-2020, 09:08 AM   #2
RL18
274
Drives: 2011 335d sport
Car is a 2010 X5M.
Either your wear sensor is bad or you need to change your brake pads. I'm leaning towards the wear sensor, happens all the time.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      08-03-2020, 09:09 AM   #3
TheeE86
24
Drives: AW
Car is a 2010 X5M.
Have you installed new wear sensors front and rear?
      08-03-2020, 09:33 AM   #4
tmvatlanta
65
2010 BMW X5M  [0.00]
I replaced the pads and rotors about 3k miles ago. I didn't replace the wear sensor as I thought it has not stripped yet.
2000 E39 Dinan M5
2010 E70 X5M
1990 Straman Z32TT
      08-03-2020, 09:53 AM   #5
TheeE86
24
Drives: AW
Most likely they need replacing. The sensor is just a wire, when they get worn the wire is “cut” creating an open in the circuit.
You can stick a wire in the vehicle end of the connector to replicate a new sensor and then reset the warning on the dashboard. But this is only temporary fix as the brake warning will come back soon (xxxx miles) after reconnecting the bad sensor.
xbimmers
