      07-09-2020, 03:39 PM   #1
krhodes1
1436
Drives: 2011 328i Wagon
2011 128i  [10.00]
2011 BMW 328i Touring  [10.00]
Figured out - Homelink retrofit in an e88 - wiring
I'm doing the Homelink mirror retrofit in my e88 128i. I have a Homelink Autodimming mirror from an e88 135i (bought from eBay), and the retrofit wiring harness. I have read a pile of DIYs and have a BMW PDF, but it's for e9X cars. What I have run into is that the FZD overhead console for the e88 is different from that for an e9x and presumably an e82 coupe. Mine does not have a 20-pin connector as all the DIYs and the PDF shows, it has a pair of 14-pin connectors, one at each end. One white, one black. I imagine everything is there, I just need to know where the new wires need to go. The mirror end is the same.
Does anyone have a pin-out for this setup? And which 14 pin connector is the right one?
Edit - I found the wiring diagrams at newtis.info, and even that seems to show a 20-pin connector. My car is a 6/2010 build, 2011 model year.
https://www.newtis.info/tisv2/a/en/e...irror/6qMeqqnV
One interesting difference - there is no rubber grommet to get the wires through in my car, there is just a good sized hole between the hard plastic header trim piece and the windshield.
I will also say, removing the mirror on these cars is enough to give one heart palpitations. BMW couldn't just use a simple wedge and screw mount like everyone else, could they...
Also, everything I have read says that the mirrors are all interchangable, but the Homelink mirror mount is different than the old one. The only one has a plastic shoe holding three spring bars that engage the mirror mount. The new one is just metal with some nubs sticking out and spring hooks. It looks like they mount the same, but is there supposed to be a plastic bit over those nubs?
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option
'11 128i Convertible - Space Gray on Savannah Beige, 6spd manual,
also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire
      07-09-2020, 10:25 PM   #2
krhodes1
1436
2011 128i  [10.00]
Figured it out! Took a couple hours of searching the web, but I found an "v2" of the retrofit instructions for the e88/e93 that had the right wiring diagram for the convertibles.
Beige connector on the left side of the overhead console:
e88-e93 wiring diagram 1 for homelink mirror by kevinr1916, on Flickr
e88-e93 wiring diagram by kevinr1916, on Flickr
Worked like a charm, all back together and working. Mirror went on fine, if a bit fiddly and equally heartstopping.
      12-06-2022, 05:13 PM   #3
Mandinca
120
Drives: 2008 E88 and 2016 F85
Trim removal
Reviving an old thread. How do you remove the trim at the top of the windshield on the E88 ? I want to put a dashcam behind the mirror and run the wires behind the trim and down behind the A panel.
Thanks
2008 E88 N54 135i / Cashmere Silver / Beige leather / VRSF catless DP's / BMW Performance Suspension / Whiteline inserts / Aluminum charge pipe and aftermarket BOV
1addicts
