TireRack
      06-28-2020, 09:06 AM   #1
Letsgo
51
Drives: 2011 BMW X5 35D
Any idea where I am leaking oil from (pics)?
2011 X5 Diesel, 120k miles.
View from inside fender (pass side)
View from top of engine (pass side)
      06-29-2020, 05:09 AM   #2
Letsgo
51
After digging around it looks like it could be a seal. I might have to clean everything up as best as I can drive the car a bit and see where exactly the oil is coming from:
Seal leak on charge air hose between intercooler and turbo.
https://xoutpost.com/748328-post3.html
This thread refers to the seals in #12:
The best thread I found refers to to oil return line:
https://www.e90post.com/forums/showthread.php?t=1576564
Looks like E90post is the best technical resource for these engines due to higher volume of participants for anyone looking for info in the future for their x5 35d.
      06-29-2020, 09:23 AM   #3
Colodano
131
Drives: 2010 X5M
Lots of possibilities, and there is oil on a bit of everything from your fill cap on down. Personally, I would say get a good steam clean done on the engine bay, and then drive it a bit to track it down.
      06-29-2020, 03:36 PM   #4
chemist_slime
18
Drives: e70 x5 35d
I tracked my turbo oil leak by adding a bottle of UV dye after cleaning the engine bay with a pressure washer (after taking precautions by taping off all the electricals of course). Then with a UV light, I found the leak coming from the charge pipe connecting to the intercooler.
https://www.autozone.com/test-scan-a...B&gclsrc=aw.ds
Make sure the oil is relatively clean though. I did this initially after 7k on the oil and it was too dark for the UV dye to fluoresce. With a fresh oil change it worked like a charm.
xbimmers
