06-20-2020, 02:47 PM | #1 |
Rep 12
Transmission Fluid Change?
Hello,
I have a 2009 125i (n52b30) with an automatic transmission (gm) It has 15,000 km on it during this 11 years Should i change ita ATF ? Dealer says it is not needed at all but i am kinda sensitive |
06-20-2020, 09:17 PM | #2 |
191
Rep 506
Drives: 2010 128i 6MT Sport Pkg. 18"
If your car has only 15,000 km. you don't need to do anything yet but you are right not to believe the "lifetime fill". If you plan to keep the car the AT fluid should probably be changed every 50,000 miles / 80,000 km.
06-20-2020, 11:22 PM | #3 | |
Rep 12
But i am worried that may be ATF could be kinda expired and lost quality because of TIME (11 years) |
06-23-2020, 03:49 PM | #4 |
191
Rep 506
Well I'm no expert on autotrans. but I don't believe time alone degrades the fluid. Having said that it certainly cannot hurt to change it and it will give you peace of mind, which I can certainly understand. You may have to do a little research on the correct fluid to use and if there's a filter involved or contact a BMW dealer.
06-26-2020, 12:44 AM | #5 | |
Rep 12
07-10-2020, 09:23 AM | #6 |
1335
Rep 1,146
Lifetime fill does not mean FOREVER nor for the lifetime you have the car, it is the LIFE expectancy of maintenance by BMW, usually 100K km's
