06-20-2020, 01:10 AM | #1 |
45
Rep 103
M3 Wishbone Only Control Arm Review
Hello everyone,
Yesterday I installed one pair of the TRW M3 control arms on my 2008 135i with 74,000kms on it, the ones referred to as the wishbones. The car rides on Michelin Pilot Super Sports in stock size with about half their life left in them. I did this in conjunction with removing the front strut alignment pin for some additional camber. The purpose of this modification was to be able to increase camber at the front wheels. Part numbers were: TRW JTC1426 TRW JTC1427 The cost (all in CAD, ON sales tax included): $225 for the two control arms (L&R) + $35 for headlight leveling rod + $0.41 for a new M10 retaining nut for the levelling rod. $135 for an alignment 3.5 hrs of my own labour for install I was curious how much of a difference the increase in camber could make on a purely spiritedly street driven car, and whether it is worth it. The answer: an immense and totally worth it difference. This is NOT a track only mod, the difference is clearly felt during turns and on on/off-ramps. The car is much more eager to turn and the increased grip and confidence in turns is remarkable. I highly recommend this for anyone with one of these cars. I hate to use this cliche, but this is how the car should have come from the factory. I can't believe how shit it was before. Next, I will install the other 2 arms, known as the tension struts, and review those as well. |
06-20-2020, 01:43 AM | #2 |
270
Rep 367
The tension struts do increase NVH quite a bit. I removed mine. Your results may vary. Roads are shit In Edmonton. Do the RSBF bushings if you haven't already. They make an equally impressive improvement.
06-20-2020, 11:52 AM | #3 |
45
Rep 103
I have little tolerance for increased NVH on this car so I'm going with Meyle HD tension struts, which are apparently better than stock but not as rough as the M3. I will definitely remove and go back to stock if NVH add is significant.
RSFB are next, but likely next season. Gotta try to stay on budget. |
06-22-2020, 08:14 PM | #4 |
1Addict
3234
Rep 7,894
Dampers are a must do item before adding the TS.
06-23-2020, 12:56 PM | #7 |
45
Rep 103
06-23-2020, 02:28 PM | #8 |
1Addict
3234
Rep 7,894
NVH. Stock dampers are underdamped and belong in the trash if you have nRFT rubber.
06-23-2020, 03:05 PM | #9 |
369
Rep 324
So was going to get the 4 piece control arm kit to install with my new Koni dampers and Eibach springs.
Do I need all 4 pieces? or should I get just the middle 2 arms (part # mentioned above)? And would I benefit from the Dinan camber plates? Sorry to thread jack |
06-23-2020, 03:07 PM | #10 | |
1Addict
3234
Rep 7,894
Afam28298.00 |
06-23-2020, 07:05 PM | #13 | |
270
Rep 367
Fakemike368.50 |
06-23-2020, 11:07 PM | #14 |
45
Rep 103
06-24-2020, 12:53 AM | #15 |
45
Rep 103
I did just the middle 3 and was very happy. I will review the remaining 2 once I install them but that will likely be next year.
Also remember that for the remaining 2 you have options: M3 or Meyle Hd. Last edited by NewDirection; 06-24-2020 at 12:54 AM.. Reason: Add info |
06-24-2020, 06:27 AM | #16 |
1Addict
3234
Rep 7,894
Meyle HD products are too hit or miss. Since there's an M3 option from TRW available If just stick with that for cheap insurance.
06-24-2020, 08:12 AM | #17 |
45
Rep 103
06-24-2020, 08:44 AM | #18 |
2707
Rep 1,916
Did the front TRW arms about 5 years ago and like the OP said it makes for a very nice improvement over stock. Arms, knocking out pins and a bit of neg camber really diminishes understeer a noticeable amount.
For those thinking about not doing the uppers, both the upper and lower arms have stiffer( better) bushings then the OE. You’re older bushings are likely pretty beat up from use now anyway. You can certainly feel the quicker response with the tightened up steering.
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams |
Fakemike368.50 |
06-24-2020, 09:24 AM | #19 |
545
Rep 1,233
I'm in Toronto, most roads are pretty shit, and I did notice a significant increase in harshness over bumps with the full set of 5 M3 control arms. I also have a B12 suspension but that was already installed so the only change was the arms.
Having said that, the increase in steering response and crispness of the front end is also significant. I'll live with the harshness I guess....in hindsight I would not have done it and just stuck with OEM replacements as I don't track my car anymore and I already had Dinan camber plates for decent front end grip. I only replaced the arms as my old bushings were worn and I had a bad front end shake under braking due to that. |
Fakemike368.50 |
06-26-2020, 06:59 AM | #20 |
647
Rep 2,051
Replaced the RFTs 8 years ago and this thread reminds me that for the entire time since then my car hasn't driven with the same sharpness in feel and turn in since then, so much lost time and opportunity...
