06-15-2020, 07:51 PM | #1 |
45
Rep 103
Coding New AHL Module
Hello everyone,
I recently fried my AHL module thorugh water leaking on my 2008 135i convertible. I replaced the burned AHL module with a NEW AHL module from BMW and am wondering about the coding. I've read a bunch of threads and am still a little confused. For a NEW module, with lights currently working and no dash codes, are these the right steps through NCSEXPERT? Open NCS F1 F3 Select E89 OK Select NFRM Back Process ECU Select RSMC Change Job <Codierdaten> Execute Job Change Job <SG Codieren> Execute Job And same procedure for LSMC The headlight now keeps looking to the far left as soon as I turn the steering wheel to lock in either direction. If I unplug and plug the headlight back in it centres but will look left again if I turn on adaptive headlights and turn the wheel. Thank you, NewD |
