06-15-2020, 05:18 PM | #1 |
69
Rep 144
Drives: 2013 BMW X5 M
Reduced Power Engine Malfunction - Boost Pressure too low
Hey Everyone:
While accelerating hard, I sometimes get the following codes from Carly: 002F24 - Charge air cooling, energy operation 002F29 - Charge air cooling, energy operation 0030FF - Boost pressure control, boost pressure too low 00310B - Boost pressure control 2, plausibility ^I believe the bold ones are the culprits So i assume this is the vacuum lines based on previous posts? is that the correct assumption should get a mechanic to inspect it? or should i pull the cover off and try to identify any lines or connectors that look like they have any damage or residue near them? I am mainly unsure how to find the leak if that is the main problem, do I need a fog machine or something? Also for replacement parts, is there a solid choice is it continuing to go with the OEM rubber lines or replacing them with higher temp silicon lines? Didn't really find a DIY guide for it, but is at easy as removing the engine plastic cover and replacing the back lines, and for the front removing the air filter? Thanks in advance! So awakening a new thread on this since the below link became hard to follow, link below for reference: https://www.xbimmers.com/forums/show...1260684&page=4
2013 E70 X5 M - SG
2001 E39 530i - M-Sport, MT,TB 2011 E93 335i - M-Sport, BSM |
06-16-2020, 01:10 AM | #2 |
2022 M4 Comp Xdrive
1016
Rep 1,539
I would replace all those vacuum lines first, inspecting them is cumbersome and you may not be able to tell anyway as a little rip is very difficult to catch.
Go with a high temp withstanding 4mm silicone hose. |
ncmoore1268.50 |
06-16-2020, 01:28 PM | #3 |
69
Rep 144
Sounds good thanks! How much do you think I should get? 10 ft seems like enough?
2013 E70 X5 M - SG
06-16-2020, 06:26 PM | #4 | |
18
Rep 69
I bought my kit here: https://www.tunemyeuro.com/cloth-cov...i-bmw-engines/ It comes in 5m which should allow you to replace all those near the top turbo and those connected to the vacuum reservoir, but not enough to replace those under the manifold. If you're doing the entire car, you'd need 10m which might have a little left over for error. All my lines were cut to factory lengths + 1cm to give some wiggle room, btw. Edit: Ah, didn't realize you have an x5m, above was for an x5 35d. Last edited by chemist_slime; 06-16-2020 at 06:43 PM.. |
ncmoore1268.50 |
06-16-2020, 07:56 PM | #5 | |
1416
Rep 1,564
Worn Wastegates Cracked CCV tubes busted Vacuum lines Worn out Vacuum pump faulty pressure converters leaky diverter valves You are in the right track and I would start off by replacing all the vacuum lines because its pretty easy and eliminate that variable. Next I would check your wastegates, if they are pretty loose then you can adjust them somewhat before you have to have them rebuilt. After that if you still have the errors check out your CCV tubes. The M has them running all over the place and the lower CCV tubes that run to the lower intakes are SO MUCH FUN to replace. Make sure not to have any young kids around if you replace them or the profanity they hear from you will warp their fragile minds... After that comes replacing the pressure converters and then the Diverter Valves |
Tags |
boost pressure too low, engine malfunction, reduced power |
