06-09-2020, 07:42 PM | #1 |
54
Rep 100
Drives: bmw 135i
no power in turbos
No power at all no check engine light either bad turbos?
06-09-2020, 08:28 PM | #3 |
54
Rep 100
Drives: bmw 135i
06-10-2020, 10:02 AM | #4 |
2314
Rep 4,341
Turbos don't just stop altogether unless they disintegrate internally and in that case, you would suck bits of impeller into your engine and you there would be no doubt. Also you have a 2011 which means you only have a single turbocharger. You have an N55 single turbo model. In the N54 earlier twin turbos the charge pipe would crack and you would lose power. I'm not sure if that is common in N55 but you most likely have a hole or maybe an stuck open wastegate if that's possible. Inspect your intake pipes for cracks. Have someone raise the rpm a bit on the car and listen for air blowing out of them. Finally, put an OBD scanner and even if no engine light on it can tell you if something is not working correctly. Good luck and let us know what you find out!
06-10-2020, 11:25 AM | #5 |
37
Rep 104
06-10-2020, 01:15 PM | #6 | |
54
Rep 100
Drives: bmw 135i
nachob2314.00 |
06-10-2020, 01:38 PM | #7 |
54
Rep 100
Drives: bmw 135i
06-10-2020, 02:12 PM | #8 |
43792
Rep 7,224
This is a pretty common problem with a simple fix, so that's good.
I feel lucky, my oe cp never blew on my old car, a 2011 135i with ~46k miles.
06-10-2020, 08:56 PM | #10 | |
2314
Rep 4,341
On a different note, I wish BMW would 1. Make some plastic that is worth a damn or 2. not use plastic in oil pans, boost pipes, valve covers. Just a thought. |
Petro135452.50 |
