05-21-2020, 05:30 PM | #1 |
Rep 6
Turbo Upgrade Advice for X5 50i
I have a 2011 BMW X5 50i, and am thinking about doing a minimal turbo upgrade - something like Stage 1 or Stage 2 Pure which use the OEM housings.
Looking for some advice on what the best turbos would be to use, and what supporting mods would be necessary. I wouldn't be interested in maxing out the potential of the turbos, just looking for around a 50 to 100 increase in Hp and torque. The vehicle is stock except for Dinan Stage 2 software. What issues would there be if upgraded turbos were installed and no other modifications were made? Would the Dinan Stage 2 be compatible or would a retune be required? |
05-22-2020, 05:24 AM | #2 | |
1416
Rep 1,564
05-22-2020, 08:34 AM | #3 | |
Rep 6
My thinking was that with a minimal turbo upgrade, I could achieve the extra power without increasing boost pressure and be at a higher efficiency and reliability range compared to pushing the stock ones close to their max pressure. |
05-22-2020, 12:19 PM | #4 |
Rep 6
Dinan technical support said that their Stage 2 software is an extra 2 psi over stock. That seems very low to me, especially considering that you said the difference between the ESS stage 1 and stage 2 alone is 3 psi.
They also said that Stage 4 is 3 psi above stock, but requires their intercooler. They did not know the stock boost pressure right off hand. |
05-22-2020, 12:51 PM | #5 | |
107
Rep 994
05-22-2020, 03:43 PM | #6 | |
1416
Rep 1,564
When I installed the ESS tune, stock boost was maxing at 10.5psi (ambient temps were in the 80s). And right after was hitting 15psi. Their stage 2 you have to run and octane booster or mix of race gas for 94aki. |
05-22-2020, 03:46 PM | #7 | |
1416
Rep 1,564
05-22-2020, 03:50 PM | #8 |
1416
Rep 1,564
True and ESS is the same, when I asked them for the stage 2, they made sure to make it clear it requires 93+ gas or bad things will happen. When I asked them about using the jb4 on top, they confirmed Stock turbos will max a 21 but it's pushing the system to it's limit and not recommend. They are alot like Dinan and tune for longevity.
05-29-2020, 11:04 PM | #9 |
Rep 6
So who could provide a tune for a minimal turbo upgrade?
Does anyone know if the stock engine can reliably handle 50 to 100 more hp and torque than Dinan Stage 2, and if that is achievable with a small turbo upgrade on 92/93 octane gas? And would any supporting mods be required? |
05-30-2020, 08:02 PM | #10 |
307
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
So boost is not the right measurement to ask about, pressure is a measure of the resistance to flow.
What you want to know is what your mass airflow is, iat, timing and fueling. Increasing MAF, lowering IAT, advancing timing and burning all that air is key. Turbo's need upgrading when they ratio of exhaust back pressure/boost pressure is > 1. In that case you're leaving power on the table due to too much back pressure. The other scenario is that your having to run the turbo outside its efficiency range to achieve your Mass air flow targets. But you'll only know this with logging. In general increasing turbo size means higher rpm's before your achieve full boost. Aka higher boost threshold (most people call this lag). They become less drivable around town, because you need more airflow through the engine to spool the bigger/heavier turbo compressor/turbine. You're 1st upgrades after a tune should be to lower intake restrictions /exhaust backpressure, especially exhaust.. Every psi of exhaust back pressure your can reduce is free hp. Anytime you increase engine output you decrease engine life, there is no free lunch. But of course does the reduction matter to you? Lots of folks have pushed over 600-700hp out of the n63, but if you plan to race the car I'd say its not gonna last long. But the extra hp only wears the engine faster if you use it. Last edited by Thecastle; 05-30-2020 at 08:30 PM.. |
