TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      05-08-2020, 08:46 AM   #1
MadHatx6
Drives: 2012 BMW X6
Unhappy 2012 X6 Cylinder Misfire & Deactivation
Hey so my bmw started misfiring and I’ve gotten a lot of different codes. The reoccurring one is that the 3rd cylinder has been deactivated due to misfire. I’ve also had codes about the absolute manifold pressure sensor, throttle body angle, and the valvtronic sensor malfunction code. These three seem to come and go randomly. I’ve already troubleshot all cylinders and they all point back to cylinder 3. After further investigation, found that the spark plug and injector was shot, so I’ve had that replaced including the coil pack for it. I STILL have a misfire on that cylinder. I’ve had the voltage checked on all the wiring that leads back to the ecu/dme and it all checks out. I am currently in the midst of getting the ECU replaced & reprogrammed, what are the odds that THIS will finally solve my problem??? 😭😭😭I just want my baby back to running normal!!! Please help. Any advice or insight would be greatly appreciated. !!!! 🙏🏾
      05-09-2020, 08:44 AM   #2
1er_vert
72
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
Carbon buildup....
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      05-11-2020, 11:49 AM   #3
MadHatx6
Drives: 2012 BMW X6
Nah it was the DME & not the ECU....so I basically just pissed away $320 to get that installed & programmed. JUST to find out that I have to get a new DME installed & programmed instead. GREAT.
      05-11-2020, 07:02 PM   #4
quick
216
Drives: '12 X5M, '01 E55, '91 964 Trbo
Who diagnosed the problem and did the work?
      05-12-2020, 10:10 PM   #5
MadHatx6
Drives: 2012 BMW X6
Bert Smith BMW did the diagnostic
Tags
bmw x6, cylinder misfire, deactivation, e71
xbimmers
