TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      05-04-2020, 05:51 AM   #1
radial
Drives: BMW X6 E71 40d (2012)
Active Sound Design retrofit to X6 E71
Hi all,
I have a 40d E71 that didn't have this as an option as I believe it was only for M50d and X6m cars. However, I'm working on a retrofitting the Top HiFi system and was considering retrofitting this at the same time while I have the car apart.
Again this will be a guide if I get it working for others to follow.
Logic 7 DSP Top HiFi system retrofit thread here ...
https://www.xbimmers.com/forums/show....php?t=1717332
Digital TV tuner retrofit here ...
https://www.xbimmers.com/forums/show....php?t=1717333
      05-04-2020, 06:08 AM   #2
radial
This is more complicated probably than it looks but I'd like to give it a go if possible.
So far from what I can work out, I need the ASD module, some wiring and some part on the exterior of the car
See here https://www.newtis.info/tisv2/a/en/e...ystem/GaRdAReW
      05-07-2020, 10:07 AM   #3
radial
Be interested to know if anyone thinks this can work on a 40d. It looks like the wiring can be done like the 50d but I wonder if something in coding will cause an issue?
      05-09-2020, 08:41 AM   #4
1er_vert
72
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
Piping sounds to your car, yields way too much HP....
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      05-09-2020, 08:56 AM   #5
radial
If only.
I mean the better option would be to change to an X6M or change out the exhaust... but they are a lot more dollar
Tags
active sound design, asd, e71, retrofit
xbimmers
