XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      03-20-2020, 10:15 AM   #1
mjoseph44141
Drives: 2014 BMW X1
How to replace inner and outer tie rods on 2014 BMW X1 AWD
need help with replacing inner and outer tie rods on 2014 BMW X1 AWD
      03-23-2020, 10:08 AM   #2
LevinBR
40
Drives: 2013 BMW X1 xDrive 35i
What (specifically) do you need help with? Removing the outer tie rods alone can be difficult if they are seized like mine were. I ended up replacing the entire assembly because I could not separate the outer tie rod ends from the inner tie rod.
The technical manual below has links to both outer tie rod and inner tie rod removal/replacement procedures:
https://www.newtis.info/tisv2/a/en/e...eering-damper/
I used pickle forks to separate the ball joints, not the special tool.
The size of the inner tie rod fastening nut (on my '13 xDrive 35i) is 38mm. Make sure to torque this to spec.
Be sure to get an alignment immediately after you finish your work.
xbimmers
