02-29-2020, 11:11 AM | #1 |
113
Rep 291
Car hesitate at light throttle
Hello, i post this in ideea someone maybe know whats happend with my car, F82 2015 dct, 6 months ago issue started, at light throttle in 5th gear car hesitate, all car bogging like a misfire, from 2 months ago started on 6th and 7th gear also but very easy not powerful like in 5th gear. I mention in 5th gear it do only at light throttle, if i press a little more the acceleration it stops and car increase speed very linear. No errors or codes on ista. Problem started on stock car and i tried with a tune but without succes.
Car have new injectors, new coils, new plugs, new aluminium charge pipes. Any modes from 6 months ago are the downpipes but same, no difference. New oil and filters at gearbox. Mention, in the morning with car cold i let it to warm like 5 minutes and when i go first 5-8 minutes no hesitate on 5th gear. I hope someone have an ideea about my problem. I think to change o2 sensors but i don t know if will solve my problem. Car run great and powerfull at full throttle. |
02-29-2020, 06:35 PM | #3 | |
1122
Rep 845
Say 5th gear 1800 rpm? If so mine does the same thing it kind of makes a deep sound and hesitates, almost drones |
02-29-2020, 06:59 PM | #4 |
113
Rep 291
Stock turbos, boost is fine at full throttle, it makes only at light throttle, under 10% acceleration and under 1600-1700rpm, most noticeable is under 1500, is not a drone, just like a short ignition or fuel cut.
If i am at low rpm and i press more the throttle, car start to accelerate very linear, no hesitate. |
02-29-2020, 07:10 PM | #5 | |
1122
Rep 845
slaughter.mode883.50 |
03-01-2020, 12:55 AM | #6 |
113
Rep 291
I want to solve this problem...
Your car do same? In the morning first 5-8 minutes of running no problems on light throttle in 5th gear? |
behindthen0thing839.50 |
05-10-2023, 02:27 PM | #7 |
65
Rep 91
05-13-2023, 06:17 AM | #8 |
113
Rep 291
Yes. Dct cars clutch wear. New clutch basket solved all problems. Car smooth again. But after 50 launches again started to do same thing but very very light, I stopped launch the car and it run fine.
